P0505 Help, EM1, tried everything I have found!
Hey guys, need some advice. I have a 1999 Si, with I believe the original B16A2. Had the motor rebuilt (in chassis) about 50K ago due to a blown valve, got 166K on it now. Been reading forums and trying things for WEEKS and am going crazy. Everything I've read indicates a vacuum leak, but I can't find it. As it sits now, engine idles at ~1500 cold and is steady. As soon as the IACV activates, starts pulsing from 1100-1900rpms non-stop.
Have been having some intermittent idle issues over the past 2 years, but have just ignored it. random high and low, then dying at a stop. Nothing to keep me from driving it. Then it started the pulsing at PT and idling at about 1500rpm and bogging hard on decel. There was another post EXACTLY like mine, he tried everything...then eventually replaced the entire intake -> to the TB and the problem was fixed. Not the solution I was looking for.
Things I have done:
1. Checked for coolant air bubble
2. Found TPS was out of adjustment, adjusted to .485v at idle and 4.5 at WOT
3. Adjusted throttle cable
4. replaced IACV (don't think the old one was bad)
5. Replaced ECU with other used one. Same result
6. Used brake-clean and sprayed all around the intake gasket, TB gasket, hoses, IACV gasket, injectors...no change in idle.
7. Cleaned TB, Sea-foamed through brake booster line.
8. replaced TB gasket
9. 50k old OEM PCV valve tests good.
10. Verified the cruise vacuum line was not disconnected.
What's next? I have an OBDII reader. only code is P0505. Thank you in advance for your help!!!
Things I have done:
Re: P0505 Help, EM1, tried everything I have found!
What's the temp reading when the engine is cold?
Does temp reading fluctuate when idle is surging?
What are the TPS reading with the scan tool?
Temp reading when cold is 73deg. After recent adjustment of the TPS, 8.2 at idle and 87.5 at WOT. Just warmed up the car. it's only 50deg outside so it only got to 180deg. I let off the gas and it was doing the hunting for 20sec, then the CEL came on. As soon as it did, the idle went from hunting to a fast pulsing around 1600rpm.
The temp reading did not fluctuate. I have a bucket with a lid, now I just need some tubing and a few cigars for the smoke test. Anything else I can try for you guys in the meantime?
Remove the air intake. Run engine until you get the high idle or surging idle. Use you finger to cover hole inside TB leading to IACV. Does idle speed drop and steady?
Your TPS is out of spec. The ecu will try to compensate using the IACV but when it's unable it will throw a code P0505. Go through the TPS calibration procedure using the fsm again.
Oh? I calibrated it to 4.5v at WOT and then adjusted the throttle plate stop screw to adjust the idle voltage. My voltages are in spec, why do you say its out of cal? What's FSM?
FSM= Factory Service Manual
Do you have one? I don't have my laptop with my copy of the FSM with me so I can't check what it gives as a spec for that engine but I believe it should be .50 volts at idle (throttle plate fully closed). You mentioned in your OP that you adjusted it to .485 volts and then mentioned the scan tool is reading 8.2 volts at idle.
Why did you adjust the throttle stop on the throttle body? I would never recommend doing that. What that will change is the overall range of movement of the throttle plate and isn't intended to be used to make minor voltage alterations to the TPS. To adjust the TPS you should be using the two screws that affix it to the throttle body and I would recommend adjusting the idle (fully closed) voltage first, not try to adjust the WOT voltage.
Ron beat me to it... lol
