P0301, P0302, P1300 1996 D16Y8 220k Miles, How have you fixed it? - Honda-Tech
Old 08-21-2011, 12:39 PM   #1
Kohen's Avatar
Default P0301, P0302, P1300 1996 D16Y8 220k Miles, How have you fixed it?
1996 Civic Coupe EX, D16Y8 with nearly 220k miles.
code definitions:
P0301 No. 1 Cylinder Misfire
P0302 No. 2 Cylinder Misfire
P1300 Random Misfire
~~EDIT~~ DRY COMPRESSION TEST- 1: 142psi 2: 20psi 3: 20psi 4: 138psi
i've tried brand new plugs, brand new wires, newer cap and rotor from my other ek, this stuff called seafoam that you dump into your gas tank which is supposed to clean your injectors and all that crap, premium gas.
symptoms: hard to start, gets pretty hot after running, it's been leaking oil for a while now i put a quart in every few days, rough/low idle, dies every once in awhile especially when taken out of a higher gear unless i give it some gas, sounds like it's missing, have to give it a lot of gas to get it going from 1st gear, trouble going up hills, trouble accelerating...
anything helps, thanks!
Kohen is offline   Reply With Quote
Old 08-21-2011, 12:45 PM   #2
The Grumpiest
grumblemarc's Avatar
Default Re: P0301, P0302, P1300 1996 D16Y8 220k Miles, How have you fixed it?
220K with problems? Get a new engine.
grumblemarc is offline   Reply With Quote
Old 08-21-2011, 12:55 PM   #3
Kohen's Avatar
yeah i have a y8 with 180k that runs like a champ i'm probably gonna put in if i don't get this GSR
Old 08-21-2011, 02:34 PM   #4
sde780's Avatar
does it smoke?
Could be a headgasket. Also is your ignition & mechanical timing good?
sde780 is offline   Reply With Quote
Old 08-21-2011, 02:37 PM   #5
Compression test the cylinders.
Former User is offline   Reply With Quote
Old 08-21-2011, 02:45 PM   #6
Kohen's Avatar
yes. lot's of blue smoke. forgot to mention that. i was also thinking a blown headgasket
and i will be testing my timing soon.
yeah i probably should do a compression test.
Old 08-21-2011, 03:08 PM   #7
Kohen's Avatar
i only tried Seafoam through my gas tank. perhaps i should also try it by mixing it with my oil?
edit: or maybe a vacuum line, from the brake booster?
http://honda-tech.com/showthread.php?t=1502112
http://www.seafoamsales.com/how-to-u...treatment.html
Old 08-21-2011, 03:17 PM   #8
Master Detailer
98civdx's Avatar
Lots of blue smoke leads me to say pistons rings need to be replaced.
When you check the timing, make you sure you the mechanical timing first, than set ignition timing.
98civdx is offline   Reply With Quote
Old 08-21-2011, 03:28 PM   #9
Kohen's Avatar
alright, will do.
Old 08-28-2011, 10:30 AM   #10
Kohen's Avatar
JUST DID A DRY COMPRESSION TEST- 1: 142psi 2: 20psi 3: 20psi 4: 138psi
Old 08-28-2011, 12:26 PM   #11
sde780's Avatar
you can thank seafoam for that
Old 08-28-2011, 04:17 PM   #12
Kohen's Avatar
for what?
Old 08-28-2011, 09:35 PM   #13
Kohen's Avatar
soo, blown headgasket, right?
Old 08-28-2011, 09:36 PM   #14
Quote:
Possibly. Do cylinder leak down tests to verify or refute.
Old 08-29-2011, 09:38 PM   #15
Kohen's Avatar
i'll be putting the new headgasket in, here in a couple days and let you guys know how that goes.
The Infamous Misfire codes... TheGageinator Honda Element & CR-V 13 09-01-2015 06:07 AM
Misfire at idle? attz0r Honda Civic / Del Sol (1992 - 2000) 1 02-20-2014 09:28 AM
2000 CRV Misfire Problems (Compression is ok) BlueWhale Honda Element & CR-V 6 01-16-2014 12:51 PM
96 civic 1&2 misfire d16y7 hon2984 Honda Civic / Del Sol (1992 - 2000) 14 11-07-2010 04:22 PM
CEL ~ Help me out! jun10r27 Honda Civic (2001 - 2005) 5 01-19-2009 09:26 AM
Tags
1996, 220k, 96, accord, civic, code, cylinder, d16y8, honda, miles, misfire, p0302, p1300, po302, seafoam
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
