overnight battery drain
Old 10-08-2015, 11:04 AM
hpiwinner's Avatar
Default overnight battery drain
Hi everyone I have a 96 civic ex coupe with a/t I'm having a problem with the battery draining overnight I've done a parasitic draw test after pulling all the fuses and got nothing still have got a 2.88 amp draw from something not sure where to go now if anyone has had this problem or can point me in the right direction would be appreciated
Old 10-08-2015, 11:14 AM
Former User's Avatar
Default Re: overnight battery drain
Originally Posted by hpiwinner
got a 2.88 amp draw
2.88 amps is HUGE. Did you mean amps or milliamps?
Old 10-08-2015, 11:23 AM
hpiwinner's Avatar
It's amps
Old 10-08-2015, 11:29 AM
That's not parasitic drain. That's a colossal short to ground.
Check the battery and alternator cables as well as hood fuse box for a short to ground. Should be easy to find using a multimeter.
Old 10-08-2015, 11:35 AM
hpiwinner's Avatar
Yeah that's what I thought too I've pulled all of fuses under hood under dash disconnected starter and alternator also replaced with a new battery and cleaned up all ground wires
Old 10-08-2015, 11:41 AM
I've...disconnected starter and alternator
Where did you disconnect them^? At the starter and alternator or at the hood fuse box?
With all fuses removed from the hood fuse box, did you test the (+) battery side of each fuse receptacle in the box for a short?
Old 10-08-2015, 11:50 AM
hpiwinner's Avatar
I unplugged the alternator green plug and disconnected ground and positive to the starter and as for the fues box under the hood i removed them one by one
Old 10-08-2015, 11:53 AM
Please read my posts carefully. Disconnect the large starter and alternator cables at the hood fuse box and then retest for the 2-amp "drain".
Old 10-08-2015, 12:52 PM
hpiwinner's Avatar
Disconnecting the two cables to the fuse box under the hood now I have no positive to the fuse box
Old 10-08-2015, 01:50 PM
The fuse box gets voltage from the battery, not from the starter or alternator. Post pictures showing exactly what you disconnected.
Old 10-08-2015, 02:10 PM
hpiwinner's Avatar
Disregard the negative cable off to save some juice
Old 10-08-2015, 03:06 PM
You lost voltage to the fuse box because one of the cables you removed comes from the (+) battery post.
Disconnect the (+) battery connector and also the alternator and battery cable attached to the hood fuse box. Use a battery jumper cable to jump voltage from the (+) battery post to the hood fuse box battery bolt to bypass the starter cable. Then check for the 2-amp short.
Old 10-08-2015, 04:44 PM
hpiwinner's Avatar
I'll perform this test they you just posted when i get back home Tuesday but i know for sure when i removed cable T101 alternator side with (+) to fuse box i didn't have the 2 amp short
Old 10-08-2015, 04:55 PM
Not sure what you did here^
Old 10-08-2015, 05:12 PM
hpiwinner's Avatar
Battery post to fuse box connect and alternator cable from fuse box disconnected had little to none amp draw
Old 10-08-2015, 05:19 PM
By removing the battery post, you remove battery voltage to the fuse box, hence no drain. Do the test I mentioned.
Old 10-08-2015, 05:30 PM
hpiwinner's Avatar
Ok I'll do the test you mentioned this coming Tuesday when i get home
Not sure what to do after post will die out
Old 10-08-2015, 05:31 PM
Not sure what you mean.
Old 10-08-2015, 05:34 PM
hpiwinner's Avatar
I'll let you know the results of the test next Tuesday and go from there
Old 10-09-2015, 04:55 AM
Fish Twig
tony_2018's Avatar
The battery will not die out as long as you remove the positive battery cable.
Old 10-09-2015, 05:20 AM
hpiwinner's Avatar
Thanks Tony but not the solution I'm looking for
Old 10-16-2015, 06:49 PM
fairwaysbill's Avatar
I had the same problem but intermittent, it was a pain in the ****, tried pulling all the fuses still draining at the same rate, turned out to be the air conditioning relay (it runs a heater apparently) which was intermittently sticking on and draining at a hell of a rate, easily enough to drain the battery overnight.
I swapped the relay for the horn relay (same type fortunately) and that cured it, the good thing is if the horn stuck on .....well you'd certainly know about it
KingofKingz80
19
09-16-2013 06:18 AM
lemonfresh
09-07-2012 01:42 PM
Westsideboy
Audio / Security / Video
11
11-13-2007 06:40 AM
RemoveGiantWingOnYourCar
11-03-2006 08:04 AM
Pooby88
07-02-2006 05:09 PM
Quick Reply: overnight battery drain
