Ok guys need some help here
Old 07-30-2007, 07:46 PM
John M's Avatar
Default Ok guys need some help here
Delete
Modified by John M at 4:00 PM 8/4/2007
Old 07-30-2007, 08:41 PM
94hondacivicvtec's Avatar
Default Re: Ok guys need some help here (John M)
have you tryed reseting the ecu?
Old 07-30-2007, 08:46 PM
Syndacate's Avatar
Default Re: Ok guys need some help here (94hondacivicvtec)
OEM Honda VTEC specs call that for VTEC to engage, the water temperature must be above 140ºF (standard operating temperature is approximately 190ºF).
VTEC will NOT engage when the engine is ice cold unless the "water temp check" is "unchecked" in a tuned ECU.
Replace the Water Temp sensor, then reset the battery, the CEL will shut off, and VTEC will come back.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 94hondacivicvtec &raquo;</TD></TR><TR><TD CLASS="quote">have you tryed reseting the ecu? </TD></TR></TABLE>
That won't work, if the water temp sensor's fucked, it's fucked, resetting the ECU won't change that.
Old 07-30-2007, 08:48 PM
Syndacate's Avatar
Default Re: Ok guys need some help here (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote">
now my clusters temp guage works so im wondering wher eis this sensor and would this cause vtec not to work? </TD></TR></TABLE>
That doesn't mean ****, it could be broken and outputting an improper voltage or something.
Replace the water temp sensor, I can almost guarantee you that's the problem.
Old 07-30-2007, 08:56 PM
John M's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">OEM Honda VTEC specs call that for VTEC to engage, the water temperature must be above 140ºF (standard operating temperature is approximately 190ºF).
That won't work, if the water temp sensor's fucked, it's fucked, resetting the ECU won't change that.</TD></TR></TABLE>
You are my hero
omg wow thankyou so much man
where is the sensor located and got a pic?
Old 07-30-2007, 09:01 PM
sk8shorty012's Avatar
Part # 37870-P7J-003
Approx. $40 from you local honda dealer.
Its located on the left hand side of the head, the sensor closest to the front of the car.
Old 07-30-2007, 09:05 PM
Syndacate's Avatar
Default Re: (sk8shorty012)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sk8shorty012 &raquo;</TD></TR><TR><TD CLASS="quote">Part # 37870-P7J-003
Its located on the left hand side of the head, the sensor closest to the front of the car.</TD></TR></TABLE>
Yeah, right next to where the upper radiator hose goes into the block.
EDIT:
I just double checked that part # because I was looking for it earlier and couldn't find it - it's the right one, OBD-II Si - but it shouldn't matter, the sensors are the same between OBD-I and OBD-II.
BUT, ON THE FLIPSIDE
I looked up the same diagram for a '94 Del Sol DOHC VTEC (OBD-I B16) and in the same diagram where it shows the water temp sensor - there's none in the OBD-I diagram.
That part number is for a 99/00 B16A2, not an A3, and I don't think a JDM one either.
@ OP:
How long have you had this swap like this? How long have you had the CEL on?
I can't find the water temp sensor on the OBD-I B16A3 block (or in your case JDM B16A). It doesn't make sense that it WOULDN'T have one but if it does it's not in the same place as it is on the OBD-II models, and I can't find the damn thing .
Maybe somebody else can help me to help you here...
Modified by Syndacate at 1:23 AM 7/31/2007
Old 07-30-2007, 09:23 PM
Syndacate's Avatar
Default Re: (Syndacate)
Old 07-30-2007, 09:30 PM
John M's Avatar
i got the car like this..... i have no clue what censor to replace or what one to take out
can someone get a pic
Old 07-30-2007, 09:39 PM
Syndacate's Avatar
Default Re: (John M)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote">i got the car like this..... i have no clue what censor to replace or what one to take out
can someone get a pic</TD></TR></TABLE>
It's under the VTEC solenoid a bit and to the right a bit - not the green plug though.
You can tell as soon as you pull it out - it's a pointy looking thing with a thermometer at the tip.
Old 07-30-2007, 09:40 PM
John M's Avatar
im broke so can u use one off a ls at the junkyard cause i can get it free due to my best friends dad owns it
Old 07-30-2007, 09:42 PM
Syndacate's Avatar
Think you meant 37870-PJ7-003
Typo.
Old 07-30-2007, 09:47 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote">im broke so can u use one off a ls at the junkyard cause i can get it free due to my best friends dad owns it</TD></TR></TABLE>
Yeah, I just checked it, the OBD-II LS and the OBD-II Si motors both have the same part number for the temp sensor.
Though like I said, I can't find a diagram or place to buy an OBD-I water temp sensor anywhere, I can't find the damn thing in terms of diagrams on OBD-I B-Series motors...
Though yeah, the water temp sensors will be the same, so you can just pull one off an LS. Though like I said, I can't find it for **** on OBD-I B series motors, maybe I'm just looking in all the wrong places...but yeah, interchangeable.
Old 07-30-2007, 10:01 PM
John M's Avatar
i hope so
the ls im gettin it off of has an older style valve cover but is a 94 and up one not a da
but will a 90-93 one work if all else fails?
Old 07-30-2007, 10:07 PM
John M's Avatar
thanks for the help guys
Old 07-30-2007, 10:09 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote">i hope so
but will a 90-93 one work if all else fails?</TD></TR></TABLE>
No idea, the OBD-I diagrams of the water pump aren't showing a water temp sensor like the OBD-II diagrams are - so I'm .
Sorry.
Old 07-30-2007, 10:53 PM
John M's Avatar
it is ok u have been th ebest help evar dude
Old 07-30-2007, 11:29 PM
Theres the diagram off a 94 Del Sol (OBD1 B16A3). Its the same part # 37870-PJ7-003. (#18 in the diagram)
Old 07-31-2007, 12:07 AM
Cool Cool Island Breezes. BOY-EE
B serious's Avatar
you sure you dont just have some plugs mixed up? The Vtec plugs and the CTS plugs are the same.
Old 07-31-2007, 12:08 AM
John M's Avatar
Default Re: (B serious)
cts?
Old 07-31-2007, 08:42 AM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by John M &raquo;</TD></TR><TR><TD CLASS="quote">cts?</TD></TR></TABLE>
CTS = Coolant Temp Sensor
The VTEC oil pressure sensor is right next to it...well sorta right next to it...anyways, it's GREEN, you want the NOT GREEN one. You can tell real easily once you pull it out, it's like a pointy cone type thing (sorta looks like a spark plug if you look at it a certain way) but its got a thermometer sensor at the tip.
http://slhondaparts.com/browse...=true
Buy this sensor:
http://slhondaparts.com/browse...7-003
And this O-Ring:
http://slhondaparts.com/browse...2-005
Those are the actual part #'s so you can just write them down and take them to a local Honda dealership, or you can order them online.
Either way, buy 'em and be done with it.
If you plan on pulling it off a junker, any B series OBD-I engine (before 96) will work and I'm 99% sure (though not positive) any OBD-II B-series will also.
Though it's only 30-35 bucks from the Honda dealership...so I'd just buy the sensor and O-ring from there...
b16bswap
14
12-11-2007 11:22 PM
mtownek9
10-21-2007 06:12 AM
ScubaSteveSi
34
08-13-2007 05:00 PM
b16nonoy
10
03-09-2007 08:58 AM
Driven
09-06-2004 09:06 PM
Quick Reply: Ok guys need some help here
