Oil in Spark plug! help please!
Old 09-10-2008, 09:19 PM
rjmancia's Avatar
Default Oil in Spark plug! help please!
well guys i have changed my grommets, head gasket, valve cover gasket many times now but i just dont get why i still keep getting oil in the 2nd plug?? the oil comes from the top soo i know that it isnt the piston rings going bad... any suggestions??
Old 09-10-2008, 10:18 PM
95dxsir2's Avatar
Default Re: Oil in Spark plug! help please! (rjmancia)
try alittle sealent on the spark plug well seal
Old 09-10-2008, 10:39 PM
footwork mastery
.Grimace's Avatar
Default Re: Oil in Spark plug! help please! (95dxsir2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95dxsir2 &raquo;</TD></TR><TR><TD CLASS="quote">try alittle sealent on the spark plug well seal</TD></TR></TABLE>
the oil isn't getting by the spark plug. so when you say grommet you replaced the one on the underside of the valve cover for each spark plug hole?
Old 09-11-2008, 08:16 AM
rjmancia's Avatar
Default Re: Oil in Spark plug! help please! (.Grimace)
nah bud i changed the ones on top after changing the valve cover gasket, what could it be???
Old 09-11-2008, 08:32 AM
EJ1_Sleeper's Avatar
There are 4 round gaskets that go inside the valve cover. it should of came with the VC gasket set. pull your vc off and flip it up side down and you will see where the wire goes through. around that hole should be a round gasket. replace those, and youll stop leaking oil into the plugs. What you replaced are the top VC bolt grommets.
Old 09-11-2008, 08:36 AM
90_EX_Civic's Avatar
Default Re: Oil in Spark plug! help please! (EJ1_Sleeper)
have you checked your valve seals? if you changed your spark plug gromments then that might be the other culprit.
Old 09-11-2008, 09:19 AM
00b20vtecoupe's Avatar
Default Re: Oil in Spark plug! help please! (90_EX_Civic)
yup its the ones under ur valve cover on the bottom side there r 4 of them one for every plug hole. take the cover off and put new ones in i got mine in a set at advance for like 25 bux with a new valve cover gasket and gromets.
Old 09-11-2008, 09:33 AM
EkFG's Avatar
Default Re: Oil in Spark plug! help please! (00b20vtecoupe)
Advance Auto Parts
Old 09-11-2008, 03:30 PM
rjmancia's Avatar
Default Re: Oil in Spark plug! help please! (EkFG)
nooo.... see bros. the thing is i changed those grommets like 3 times and still leaking but i noticed today that it wasnt bad leaking sooo that was kinda wierd hahaha... but i think it is fixed thanks though
Old 09-11-2008, 08:04 PM
If there's still oil, and you did change the grommets, it's probably your valve seals.
Old 09-11-2008, 08:27 PM
96Spec Ek's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EX_Civic &raquo;</TD></TR><TR><TD CLASS="quote">If there's still oil, and you did change the grommets, it's probably your valve seals. </TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90_EX_Civic &raquo;</TD></TR><TR><TD CLASS="quote">have you checked your valve seals? if you changed your spark plug gromments then that might be the other culprit. </TD></TR></TABLE>
No, no, and no
Old 09-12-2008, 09:06 AM
rjmancia's Avatar
Default Re: Oil in Spark plug! help please! (96Spec Ek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 96Spec Ek &raquo;</TD></TR><TR><TD CLASS="quote">
No, no, and no </TD></TR></TABLE>wat u think then bud??
Old 09-12-2008, 03:33 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rjmancia &raquo;</TD></TR><TR><TD CLASS="quote">wat u think then bud??</TD></TR></TABLE>
x2
yeah, what would you suggest then? he said that he already changed head gasket, valve cover gasket and the grommets. usually if all that is fixed and he still has oil in the spark plug hole the only other suggestion would be valve seal. so, what else could it be??
Old 09-12-2008, 03:41 PM
footwork mastery
.Grimace's Avatar
it's not the valve seals. lol that doesn't even make sense
Old 09-12-2008, 11:22 PM
rjmancia's Avatar
true.... hahaha! hmmm... damn i dont know but owell its not hurting anything at the moment
Old 09-13-2008, 08:57 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Grimace &raquo;</TD></TR><TR><TD CLASS="quote">it's not the valve seals. lol that doesn't even make sense</TD></TR></TABLE>
you do know honda's have a upper seal and a lower seal for the valves, right? so if one of the seals is bad then its getting in trough the valve train. basically saying that he checked on top and on the bottom, but he didn't check in the middle(valve seal)
zaida08bk
06-26-2014 09:06 AM
thegooddoctorceretti
10-11-2007 02:50 PM
lgharis
05-23-2007 06:10 PM
civicxspower
06-05-2005 04:12 PM
Civic
05-08-2003 08:09 AM
Quick Reply: Oil in Spark plug! help please!
