oil pan swap any tips?
getting ready to put my pretapped oil pan on for my turbo install this weekend
and wanted to ask for a couple tips on this
I have the brand new oil pan rubber fel pro gasket
is it a good idea to use silicone with this or should you just remove the old oil pan and simply bolt the new one with new gasket up and torque to spec
btw what is the torque or oil pan bolts?
Re: oil pan swap any tips? (Civic Racer X 7)
You should put a little sealant on both of the ends that have the recess for the crank. I like to also add a dot in the middle on both sides to help old the gasket in place
stets
10
03-02-2008 04:12 PM
deconstruct
06-18-2004 01:00 PM
