Oil pan gasket on 2000 Civic with b16 swap
Old 11-10-2010, 01:13 PM
rubikscube's Avatar
Default Oil pan gasket on 2000 Civic with b16 swap
My oil pan is leaking like a sieve. The gasket is bad. I have a new one and am going to replace it. How long does it take? I read online some places say it's a 2 and a half hour job? Car is a 2000 ex coupe with a b16 swap.
Old 11-10-2010, 01:20 PM
Former Moderator
B18C5-EH2's Avatar
Default Re: Oil pan gasket on 2000 Civic with b16 swap
Generally speaking the job pays 2 hours. if you're a tech.
There are a few factors that go into whether the job takes 1 hour or 3.
Do you have a 1 piece or two piece header/exhaust a-pipe? You need to remove it to get the pan out.
Will the old gasket be baked on so badly that you have to use a torch to heat it up, and scrape it off, or will it peel off easily allowing you to simply cookie the old Hondabond/RVT sealant off that remains?
I've seen the most competent, fast techs do that job in in 45 mins. I've also seen the exact same tech have it take 3 hours because he quite literally had to remove a one piece header and torch the old pan gasket off, then wire wheel the pan gasket mating surface because someone used an entire tube of RVT sealant all over the pan and gasket.
abiliojr
06-19-2013 07:51 AM
xTomei
13
12-11-2010 07:38 AM
StreetRacinThug
12-21-2006 08:44 AM
standbackimapro
12-17-2005 01:12 PM
turbo Si
06-11-2003 06:26 AM
Quick Reply: Oil pan gasket on 2000 Civic with b16 swap
