Oil leak!!! HELP!!!!
Old 03-01-2009, 02:49 PM
keychild486's Avatar
Default Oil leak!!! HELP!!!!
i have a 96 civic with an ls.vtec swap. i changed my oil pan gasket thinking i had an oil pan leak. after i changed the gasket it started to leak again. i looked up to see that i had a oil leak coming from the block. i don't know the name of the part and the gasket to get. i have a pic with an arrow pointing to the leak.
Old 03-01-2009, 03:41 PM
ccarey's Avatar
Default Re: Oil leak!!! HELP!!!!
You may have a rear main seal leak is what it sounds like
Old 03-01-2009, 03:51 PM
be professional
Targa250R's Avatar
That's part of the oil pump. There's an O-ring behind there, part number 91302-PF0-003.
That's the front side of the engine.
Old 03-01-2009, 03:54 PM
ccarey's Avatar
sorry cant see pics on my work computer so just guessing on that one.
Old 03-01-2009, 04:14 PM
Sol to Sol
JarvisW's Avatar
Yep, oil pump. rear main is no where near the belts
Old 03-01-2009, 04:29 PM
devney's Avatar
x2
Old 03-01-2009, 04:32 PM
Former User's Avatar
Is oil also dripping out of the weep hole at the bottom of the lower timing belt cover (not visible in picture)? If so, the oil leak could possibly be originating from the cam seal or even from the driver's side of the valve cover. You'll definitely identify the leak source (oil pump, cam seal, valve cover) when both timing belt covers are removed.
Old 03-01-2009, 04:44 PM
be professional
Targa250R's Avatar
x2.
When checking for oil leak sources, you must work from the top of the engine down, not from the bottom up. Cleaning the engine thoroughly with degreaser beforehand and using oil trace dye with a blacklight makes easy work of it.
keychild486
03-02-2009 12:07 PM
Quickridez_3
05-01-2008 12:17 AM
mwstrick
07-24-2007 09:19 PM
Quick Reply: Oil leak!!! HELP!!!!
