OIL DRIPPING
OIL DRIPPING
I CHANGED MY PASSENGER SIDE AXEL ON FRIDAY...NOW MY CAR IS DRIPPING OIL FROM WHERE THE AXEL GOES IN THE TRANNY.....BEFORE I CHANGED THE AXEL IT NEVER LEAKED OIL...ANY ONE KNOW WHAT COULD BE WRONG...
Re: OIL DRIPPING (97JDMEKSLEEPER)
Stop driving the car imedietly! You can cause sever damage to the new tranny if you drive it!
Goto honda (In anther car obviously)
Get a new seal (Bring in the old one)
Remove the axle from the tranny side only
Remove the old seal
Install the new seal
Reinstall the axle
Fill with oil check for leaks
Those seals are only meant to be ussed once aka installed once they can tear pretty easily. The reason i say dont drive the car is because if you lose to much oil your burn up a bearing, gear, syncro, ext. I did it once on my Si and the tranny lasted about 500 miles b4 the fith gear burned up Also bring in the old seal to honda because i ordered one and it was the wrong one, Hence why i had a leak dident check it to be sure it was the same so. Shouldent take you more then 30min to fix
Remove the old seal
Reinstall the axle
Re: OIL DRIPPING (nocternaldragon)
What seal do i have to get? oh and i have a type r lsd tranny...so i should go 2 acura?
Modified by 97JDMEKSLEEPER at 10:35 AM 9/13/2004
serious
04-08-2003 03:47 AM
