Question regarding 2000 civic lowering springs
Old 09-09-2008, 11:52 PM
ic3pham's Avatar
Default Question regarding 2000 civic lowering springs
I have S tech Tein springs on my 2000 civic ex right now. I want to switch the TEIN spring with stock civic springs. Will I need to get a new rubber stop for the stock springs because the rubber stop I have on my car right now is cut to fit the lowered TEIN springs. You answer is much appreciate it.
If I don't get a new stock rubber stop and use the cut one with the stock civic springs. What will be the negative affect if I do this?
Old 09-10-2008, 09:40 AM
boondox_saint's Avatar
Default Re: Question regarding 2000 civic lowering springs (ic3pham)
If you do not replace it then it might be a bit harsher when you bottom out your suspension because that extra bit of travel on the bump stop is gone. Personally I wouldn't worry about it.
Old 09-12-2008, 07:38 PM
ic3pham's Avatar
Default Re: Question regarding 2000 civic lowering springs (boondox_saint)
bump any one else have an answer for this?
Old 09-12-2008, 07:48 PM
Burnt Toast's Avatar
I am assuming the Tein's were used on your stock struts to lower your car and now you want to go back to a stock height and install the stock springs. You can use the cut down bump stops and it will not hurt a thing. The only reason you cut them in the first place is to give your car an extra inch of travel which was lost when you lowered it.
MikeyM718
Suspension & Brakes
04-12-2012 09:02 AM
lando griffin
Suspension & Brakes
01-19-2008 02:06 AM
tomu06
08-18-2006 09:11 PM
B16CivicEX
06-30-2006 07:37 PM
aznryd3r
10-25-2005 03:18 PM
Quick Reply: Question regarding 2000 civic lowering springs
