oem key fob
oem key fob
Does anyone here know how to re-program factory key fobs so that they work? Its for a 1998 civic ex. I searched and came up with this solution. But when I tried it, it didn't seem to work. I tried doing step 2-3 really quick, didn't work, so I tried really slow, didn't work, and I also tried holding down the lock buttons, didn't work. I dont know why it wont let me into the programming mode. Help me.....
KEYLESS ENTRY PROGRAMMING
Have all remotes for the vehicle on hand.
Make sure all the doors and rear hatch/trunk are closed during programming.
Only need to use 1 remote to get into program mode but all remotes must be programmed during the same session.
Each step must be completed within 5 seconds.
1. Sit in the car with all doors/trunk tightly closed
2. Turn the key to the ON position, marked by "II" on the ignition bezel so the dash lights come on, then within 5 seconds press the "Lock" button on the remote for 1 second or so and release the button.
3. Turn the key to the OFF position, marked by "I" on the ignition bezel - dash lights go off.
4. Repeat steps 2 & 3 three more times (A total of 4 times) - each step must be done within 5 seconds of the previous step.
5. Upon the 4th turning of the key to "ON", press the lock button on one remote, the locks will make a cycling sound (clunk), locks will NOT lock or unlock at this point, they will just make a noise. The system is now in programming mode. Do not turn key off.
6. Within 5 seconds of entering programming mode and within 5 seconds of each other, press the lock button ON EACH remote you are programming, for a second or so and release. This step needs to be completed within 10 seconds. Each time a remote button is pushed, the locks should cycle. Up to 3 remotes can be programmed.
Re: oem key fob
hey thanks RonJ I'll give it a try. I was trying to private mssg you but for some reason I couldn't. I need help and advice from you on building an engine. You seem to be the most help around here in HT and your knowledge seems to be very high. Is there a way I can pm you?
petertiernan64
Audio / Security / Video
05-15-2017 03:41 AM
ct976
07-12-2005 09:01 AM
