OBD2 port not working - Honda-Tech
Old 10-19-2011, 11:20 PM   #1
Default OBD2 port not working
I put a b16a jdm engine into my 97 civic ex. I want to get it bar'dm but my obd port isn't working. Can it be that that I have a jdm ecu? (p2t).
That is the only thing holding me back....
any help is appreciated! ( and yes i am a noob, trying to learn!)
Eddy562 is offline   Reply With Quote
Old 10-20-2011, 07:15 AM   #2
b16a2ek's Avatar
Default Re: OBD2 port not working
what year is the b16? i have a b16 from the 2000 si and am running a jdm p2t with no problems but i did need a jumper harness to go from obd2a to obd2b due to the wiring harness for the car being different
b16a2ek is offline   Reply With Quote
Old 10-20-2011, 07:18 AM   #3
The Grumpiest
grumblemarc's Avatar
Quote:
Originally Posted by Eddy562 View Post
...a b16a jdm engine...
This is your problem.
grumblemarc is offline   Reply With Quote
Old 10-20-2011, 08:05 AM   #4
I have a jdm ecu? (p2t).... this is the problem that ecu dont support the diagnostics port
apexi_rsx is offline   Reply With Quote
Old 10-20-2011, 02:53 PM   #5
Kista20's Avatar
Quote:
I'd say you hit the nail right on the head there. You will need to run a usdm ecu.
Kista20 is offline   Reply With Quote
Old 10-20-2011, 11:14 PM   #6
Quote:
the engine is from 99/2000 si
how much was the harness and what kind?
Old 10-20-2011, 11:15 PM   #7
Quote:
Will my d16 ecu work on the b16? it is a usdm p2p?
Thanks again
Old 10-20-2011, 11:24 PM   #8
Old 10-21-2011, 05:00 AM   #9
The Grumpiest
Nope. Did you not research this before you did the swap?
Old 10-21-2011, 08:20 AM   #10
dpetro1's Avatar
The car should run. Just not properly. Probably won't pass BAR that way
dpetro1 is offline   Reply With Quote
Old 10-22-2011, 12:28 AM   #11
So should I try and get the ecu of the b16a2? what would be the difference?
Old 10-22-2011, 12:29 AM   #12
Quote:
What do you recommend for me to be able to pass?
Thanks
Old 10-22-2011, 07:13 AM   #13
get a usdm b16 ecu from a 99-00 si or a b16 del sol
Old 10-22-2011, 07:51 AM   #14
Alright, just out of curiosity, how would it change by switching ecu's, performance wise, should I still use the jdm ecu after I get everything bar'd?
Old 10-22-2011, 08:03 AM   #15
switching ecu's will not do much both usdm b16 makes similar power to the jdm b16. the jdm ecu redline is 8200 vs usdm 8000 and vtec engagement for the jdm is 5800 and usdm is 5600. just little ecu tweaks are the differance. the jdm motor just has a slight bump in compression over the usdm b16. 10:6 vs 10:2
Old 10-22-2011, 08:20 AM   #16
Jdm ecus do not communicate with usdm scan tools that is the reason behind your issue. Also since you are trying to bar your car, try to find a 96-97 p30 from a 96-97 del sol dohc vtec. The bar techs wont take kindly to jumper harnesses and the wrong ecu.
jayWknight is offline   Reply With Quote
Old 10-22-2011, 04:47 PM   #17
Thanks everybody! I will try to buy everything on my next check and let you guys know how it went
OBD port fuse? Charlienofun Honda Civic / Del Sol (1992 - 2000) 3 01-31-2015 08:28 PM
OBD port problem: POWER fasterthanrayswrx Honda Civic / Del Sol (1992 - 2000) 8 01-29-2007 05:15 PM
obd-2 port on 97 Del Sol teler86 Honda Civic / Del Sol (1992 - 2000) 2 10-08-2006 07:25 PM
electronic ?????? ELISR20DET Honda Civic / Del Sol (1992 - 2000) 0 09-27-2006 10:15 AM
OBD connector not reading ctr status Honda Civic / Del Sol (1992 - 2000) 6 09-14-2006 06:10 PM
Tags
2002, 96, accord, civic, connector, honda, isnt, lx, obd, obd2, odb, p2t, port, responding, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
