d16y7 idle issue
Old 10-22-2011, 03:04 PM
z0mby's Avatar
Default d16y7 idle issue
Ok, so sometimes I get in my car and go wherever and the motor runs fine. Idles nice on a cold motor(800-1000rpm). However, as my motor warms up, I'm starting to get an idle of 1500-2000. I do the usual thing to keep it down by pressing the gas and it goes back down to 1000 and rapidly just increases back to 1500. Then, as I continue to let it idle, it'll go up to 2000. I've taken the IACV off and cleaned it, reinstalled it and it'll do fine until the car warms up. I don't have any vaccuum leaks(from what I can see). There's no CEL's, nothing. Any ideas? Sometimes I'll mash the gas up to 3500-4000 rpm and then the idle will drop to around 1200 and stay there for a little while. Then a couple miles down the road it'll go back up to 1500-2000. Again, any ideas?
Old 10-22-2011, 04:09 PM
motegicivic's Avatar
Default Re: d16y7 idle issue
Have you cleaned your throttle body?
When was your last tune up?
Old 10-22-2011, 04:26 PM
z0mby's Avatar
No, I haven't cleaned the throttle body. I will do that tomorrow.
New timing belt, new plugs and wires bout a month and a half ago.
Old 10-22-2011, 04:32 PM
Also check the throttle cable, make it is not binding.
Might want to check the TPS as well.
Another thing, who did the timing belt, did they adjust the timing?
BigFudge
07-05-2013 03:08 PM
dirtyharryhatch
12-14-2011 05:45 PM
ATS*Mark
12
12-22-2005 07:14 PM
stRodda
01-13-2004 04:32 PM
delSolLS
02-18-2002 04:59 AM
Quick Reply: d16y7 idle issue
