OBD2 port not working?
Old 07-03-2006, 02:58 PM
slowpokecivic's Avatar
Default OBD2 port not working?
went to the state ref today and failed...
but the weird thing is that they told me that they couldnt communicate with the ecu...where can i go to check this out and how do i fix this...?
Old 07-03-2006, 03:02 PM
Default Re: OBD2 port not working? (SLoWpOkECiViC)
so the state ref assumed the ecu was jdm...
Old 07-03-2006, 03:54 PM
B16CivicEX's Avatar
i have a JDM use , obd 2 to obd1 harness, and same thing here the CEL is on and the reader said can not comm with vehical. bump
Old 07-03-2006, 07:02 PM
Default Re: (AirForceB16)
the thing is i have an usdm ecu...obd2a car with obd2a ecu...
i think ima go to autozone and see if they can read it...
Modified by SLoWpOkECiViC at 12:58 AM 7/4/2006
Old 07-03-2006, 07:47 PM
oOoBanana's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AirForceB16 &raquo;</TD></TR><TR><TD CLASS="quote">i have a JDM use , obd 2 to obd1 harness, and same thing here the CEL is on and the reader said can not comm with vehical. bump</TD></TR></TABLE>
the reason why its not reading it because its an obd1 ecu and it needs to read an obd2 ecu...
Old 07-03-2006, 07:51 PM
EX-T's Avatar
Default Re: (SLoWpOkECiViC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SLoWpOkECiViC &raquo;</TD></TR><TR><TD CLASS="quote">the thing is i have an usdm ecu...obd21a car with obda2a ecu...
i think ima go to autozone and see if they can read it...</TD></TR></TABLE>
What the hell is an obd21a and obda2a ecu??????????
Do you have a CEL on?
Old 07-03-2006, 11:58 PM
Default Re: (EX-T)
oops...typed that wrong...edited
Old 07-05-2006, 09:08 AM
and yes i do have a CEL...but the jumper harness works so i already checked my codes...but the diagnositc plug on the other hand does not work or so what the state referee told me. im going to kragen today after work to check it out....
Old 07-06-2006, 07:05 PM
ended up going to autozone and they were able to check the codes...
does that mean the machine at the state ref was not working? or do their machines do a whole different thing?
Old 07-07-2006, 12:15 PM
no one can help?
Old 07-07-2006, 12:31 PM
Luserkid's Avatar
If an autozone scanner works on your car then the ref just didnt want to deal with you. If thats the case, rent the scanner and take it to the ref and ask them why there hightech scanner doesnt work when a piece of **** autozone one does. If thats the only reason why they failed you you could take them to court and if you win, you never have to worry about a state ref again (for that car).
Old 07-10-2006, 09:18 AM
Default Re: (Luserkid)
do you guys think that their scanner couldnt communicate with the ecu because the ecu just got resetted?
RACEPAK
10-31-2007 11:48 AM
HondamanXxX
08-10-2007 10:27 PM
CeeJayy
07-27-2007 07:48 PM
3rdgencrx
12
02-14-2007 05:26 PM
G"UNIT
10-27-2004 05:23 AM
Quick Reply: OBD2 port not working?
