obd2 to obd1 injector harness?
Old 08-21-2007, 04:37 PM
vtecftw's Avatar
Default obd2 to obd1 injector harness?
alright obd1 motor in obd2 car
will i need the obd1 D injector harness, because the obd2 clips wont connect?
i have the ecu conversion harness and the dizzy conversion harness
Old 08-21-2007, 05:27 PM
slowcivic2k's Avatar
Default Re: obd2 to obd1 injector harness? (vtecftw)
Which engine are you throwing in there?
I swapped a B16A in my 2000 civic, and used the D16 injectors, same flow. I don't like hacking wires when it isn't at all necessary.
Old 08-21-2007, 05:37 PM
Syndacate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecftw &raquo;</TD></TR><TR><TD CLASS="quote">alright obd1 motor in obd2 car
i have the ecu conversion harness and the dizzy conversion harness</TD></TR></TABLE>
Just use the OBD-II injectors.
They'll be sufficient.
Old 08-21-2007, 06:21 PM
vtecftw's Avatar
what else are my options i only have the obd1 injectors its a d16 obd1
Old 09-17-2007, 04:50 PM
SJersey's Avatar
Default Re: (vtecftw)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtecftw &raquo;</TD></TR><TR><TD CLASS="quote">what else are my options i only have the obd1 injectors its a d16 obd1</TD></TR></TABLE>
I have a jumper harness for you. http://kgparts.com/forums/kgp-...t1433
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slowcivic2k &raquo;</TD></TR><TR><TD CLASS="quote">I don't like hacking wires when it isn't at all necessary.</TD></TR></TABLE>
Thats why we started to offer them to the public
Old 09-17-2007, 04:55 PM
Kyoh's Avatar
Default Re: obd2 to obd1 injector harness? (Syndacate)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Syndacate &raquo;</TD></TR><TR><TD CLASS="quote">
They'll be sufficient.</TD></TR></TABLE>
X2
I'm putting an OBD-II B16 in my OBD-I car, just used my D series OBD-I injectors.
Old 09-17-2007, 05:10 PM
egsleepercivic's Avatar
Default Re: obd2 to obd1 injector harness? (Kyoh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kyoh &raquo;</TD></TR><TR><TD CLASS="quote">
X2
I'm putting an OBD-II B16 in my OBD-I car, just used my D series OBD-I injectors. </TD></TR></TABLE>
they are the same except for the connector is different otherwise they are the same
Old 09-18-2007, 10:29 AM
Kyoh's Avatar
Default Re: obd2 to obd1 injector harness? (egsleepercivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by egsleepercivic &raquo;</TD></TR><TR><TD CLASS="quote">
they are the same except for the connector is different otherwise they are the same</TD></TR></TABLE>
Well exactly, that's why I couldn't use the OBD2 ones. That's why I put the OBD1 ones in, cause the connections didn't work.
Old 09-18-2007, 11:44 AM
B18CivicEJ8's Avatar
Just modify the injector clips...
https://honda-tech.com/zerothread?id=1936840
Superqwak
08-16-2012 09:00 PM
boostin92hatch
04-16-2010 10:42 AM
novaslean
04-14-2010 09:23 AM
mr.k24
09-20-2009 09:38 PM
shorty5198
Honda Civic (2001 - 2005)
07-25-2006 05:25 AM
Quick Reply: obd2 to obd1 injector harness?
