What is my 94 Civic leaking if it isn't oil?
I have a Honda Civic 94 Hatchback and it's leaking something. It's not oil because I have checked it if it has been loosing oil but it hasn't. What else could it be leaking? Or is it burnt oil?
Re: What is my 94 Civic leaking if it isn't oil?
Get underneath ur car and see if u notice any oil markings. If u do that then ushould be able to see the area that the oil is coming from. It could be brake fluid. Oil power stearing fluid. Transmission fluid. Anything really
just because the oil level hasn't dropped doesn't mean it's NOT oil..... assuming the engine is very clean spray some brake clean on the known leak places ex:cam seal vtec sol, distributer, etc
Use 3' x 3' piece of cardboard and paint it white or use white poster-board. Mark front, back, passenger and driver side respectively on cardboard or poster-board. Stick it under the car and leave it there for 30 minutes. Take a pic of the cardboard and post it for us.
no it's like 10-12 8mm bolts you'll need to drop the exhaust manifold to drop the pan not hard. Just be really carefully when you're tightening the bolts after you replace it they like to snap/strip easily.
