o2 sensor, 92 dx hatch
My ecu is a p06, what o2 sensor do i need? the engine harness only has 1 wire for my o2 sensor but the o2 sensor in the manifold is a 4 wire. Do I need to get a 1 wire o2 sensor so it just plugs in or do i need to hard wire in the 4 wire o2 sensor for it to work properly?
Re: o2 sensor, 92 dx hatch
Yeah sounds like you have a cx. I had this problem and just ended up buying a 4wire O2 harness and wiring it directly into the ECU. It worked great.
i just did a swap on my 95 hatch that had a cx (d15b8) motor and harness to a dx motor with cx harness and am running a p06 ecu. i had to rewire in a 4 wire but only took about 20 mins. These are the links i used:
http://nzhondas.com/tech-help/123612...sion-obd1.html
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/92-00-honda-engine-swap-wiring-guide-vtec-non-vtec-2987229/
i spent hours researching so let me know if you need any help
After hours and hours of digging and looking and researching this is what I came up with. Car is a 92 DX Hatch, the engine harness that was sold to me was for a CX (1 wire o2 sensor) problem should be solved by purchasing a proper engine harness for my car and then we will be golden. From what I have found and been told anyhow
Markb16a
05-13-2007 08:26 PM
chad
08-25-2004 01:58 PM
civicmatt
06-22-2003 07:27 PM
civicracer1993
02-11-2003 06:35 PM
