Noob Q bout Oil Filter Install
Hi guys I just had a simple question. What would happen if I forgot to fill the oil filter halfway with oil when installing it? I did oil the seals but forgot to fill half of the filter with oil.
Thanks in advance
Thanks in advance
Re: Noob Q bout Oil Filter Install (flipp117)
nothing.... i thought they just recommend that you put oil on the gasket so it will be easier to remove the next time u change the filter. I've changed my oil filter numerous of times and never filled my oil filter w/ oil before the install
Re: (HeterHsan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HeterHsan »</TD></TR><TR><TD CLASS="quote">what is the beneifit of putting oil in the filter? i have done plenty of oil changes to say that you dont have to at all.</TD></TR></TABLE>
it's called charging the filter. It's just a precaution to have the complete 4.2qt of oil or however much ur car holds in the engine and not in the filter. I just think its necessary to put a layer of new oil around the rubber gasket of the new filter to ease the pain of taking the filter off after use. I just put in a little extra oil to compensate for charging the filter.
Re: (Sijray21)
forgive me if i am wrong, but what does it have to do with removing the filter the next time?
i always thought that oiling the gasket was to make a proper seal to the motor.
the gasket is not holding the filter up there.
also the motor oil all goes through the filter so i dont think it has anything to do with it not being in the motor and in the filter instead.
i think the reason for doing this is for the motor to immediatly get oil from the filter and not be dry for even a second.
Re: (riversideguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riversideguy »</TD></TR><TR><TD CLASS="quote">I thought oiling the filter prevents tearing the filter ring and improves the seal. Dry rubber probably doesn't slip into place well.</TD></TR></TABLE>
yes, that's the reason.
holmesnmanny
12-10-2009 03:14 AM
happynoodleboy
02-20-2008 06:34 PM
dclub01
05-01-2003 03:22 PM
