non-oem replacement bolts for suspension
Old 11-28-2006, 07:33 PM
quest4boost's Avatar
Default non-oem replacement bolts for suspension
im doing a bunch of things on my ej8 which requires the suspension to be removed. the nuts and bolts that i took out look really rusted out so i'd like to replace them. problem is, the dealer wants $13 CND for the bolt that connects the front damper fork to the lower control arm, so you can imagine how much other bolts cost. for $13, i could buy an entire bucket from the hardware store.
so does anyone use bolts from their local automotive stores? any problems? i'll be using the strongest stuff i can find btw.
Old 11-28-2006, 07:42 PM
NSfit's Avatar
Default Re: non-oem replacement bolts for suspension (quest4boost)
yeah i do! just so nice grade 8 bolts with either lock washers and nut or a locking nut
Old 11-28-2006, 07:43 PM
NSfit's Avatar
Default Re: non-oem replacement bolts for suspension (NScivic)
iv had them on for about a year and a half now and iv taken my suspension apart a few times and the is no abnormal wear to them
Old 11-28-2006, 07:51 PM
Andres-eh2's Avatar
went to the junkyard a couple of times and grabbed a few laying on the ground. i personally would only use OEM.
Old 11-29-2006, 05:09 AM
Default Re: (Andres-eh2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Andres-eh2 &raquo;</TD></TR><TR><TD CLASS="quote">went to the junkyard a couple of times and grabbed a few laying on the ground. i personally would only use OEM. </TD></TR></TABLE>
if i had to choose between used oem bolts of unknown origin and new non-oem bolts, i would be inclined to go with the new bolts instead. and i'd like to use oem exclusively, but not at ~$13 a pop.
Old 11-29-2006, 05:27 AM
The G2 Racer's Avatar
Default Re: (quest4boost)
Since your in Toronto, go to a Brafasco.
Whenever I need a bolt to replace a broken on that's where I go. They've never let me down.
Old 11-29-2006, 05:42 AM
sicones's Avatar
Default Re: (The G2 Racer)
if you buy a bucket of bolts from the hardware store and install them on your suspension you will die , OEM honda bolts are grade 8 or better, the **** you get from the hardware store are grade 5 or worse. Some of the bolt are specially desinged too, there threaded up to a certain point, have ribs on them, have shaper points to get them to go through bushings etc.
Old 11-29-2006, 02:07 PM
NSfit's Avatar
Default Re: (sicones)
i don't know where your shopping at but the hardwood stores by my house have even better bolts then grade 8. like hardened
Old 11-29-2006, 03:10 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones &raquo;</TD></TR><TR><TD CLASS="quote">if you buy a bucket of bolts from the hardware store and install them on your suspension you will die , OEM honda bolts are grade 8 or better, the **** you get from the hardware store are grade 5 or worse. Some of the bolt are specially desinged too, there threaded up to a certain point, have ribs on them, have shaper points to get them to go through bushings etc.</TD></TR></TABLE>
That's why I suggested Brafasco. They have grade 8, grade 10, etc.
Old 11-29-2006, 03:55 PM
Crx Jimmy's Avatar
i would use the honda bolt at least for the damper fork, they have grooves in them that stop it from getting rusted to the sleeve if you use a regular bolt it could rust to the sleeve and have fun cutting it off
Old 11-29-2006, 05:56 PM
Default Re: non-oem replacement bolts for suspension (Crx Jimmy)
Zinc coated or stainless steel bolts are your friend.
mikej94civex
06-25-2010 05:21 AM
Civicse
16
12-20-2005 06:45 PM
Wazup
Suspension & Brakes
11
07-27-2005 11:42 PM
FastSS
04-01-2003 04:07 PM
Chris_
15
06-20-2002 01:17 PM
Quick Reply: non-oem replacement bolts for suspension
