No turn signals but hazards work - Honda-Tech
Closed Thread
Old 09-15-2011, 01:09 AM   #1
cevax's Avatar
Default No turn signals but hazards work
Ok so this is drving me insane, The hazards work but the turn signals do not. I replaced the Flasher relay on the wiring harness, the light and signal switch on the steering columns. My brake lights etc all work so its not the fuse in the fuse box. Also replaced the hazard switch just in case and no go. This is a 93 del sol S with a 1995 del sol SI dash harness swap, everything but the turn signals work but I am not sure if this harness is different.
Also this is the light switch, the three pin plug on the top, is that supposed to be connected? it wasn't and I cant find a cable that is supposed to go there. If something even goes there.
The hazards work and they turn on when the headlights are on just don't blink
cevax is offline
Old 09-15-2011, 01:23 AM   #2
Default Re: No turn signals but hazards work
I'd say the issue is with your turn signal stalk...
fleabag is offline
Old 09-15-2011, 04:38 AM   #3
cevax's Avatar
turn signal stalk?
cevax is offline
Old 09-15-2011, 04:40 AM   #4
cevax's Avatar
I replaced that already
here is the new one
cevax is offline
Old 09-15-2011, 06:24 AM   #5
Check the turn signal fuse in the dash fuse box.
10A dash fuse 15
Former User is offline
Old 09-15-2011, 06:55 AM   #6
cevax's Avatar
Ok I will post back when I do
cevax is offline
Old 09-15-2011, 07:08 AM   #7
cevax's Avatar
fuse 15 is good, I tried another just to make sure and no go
cevax is offline
Old 09-15-2011, 08:07 AM   #8
I guess it could be the wiring going to the turn signal stalk. Isn't there a test procedure for this in the helms service manual?
fleabag is offline
Old 09-15-2011, 10:25 AM   #9
cevax's Avatar
I have a chilton manual, that is 300 pages of pure pure vagueness, completely useless
cevax is offline
Old 09-15-2011, 12:53 PM   #10
Use a multimeter to test whether the hazard switch gets voltage from fuse 15.
Old 09-15-2011, 03:38 PM   #11
Quote:
You need to get a helms.. They're like $40 on ebay, though in this instance, you'll actually need to buy the Honda Electrical Wiring diagram.
fleabag is offline
Old 09-15-2011, 05:16 PM   #12
cevax's Avatar
Quote:
I will grab a meter and test it in the morning and post what I find
cevax is offline
Old 09-15-2011, 05:24 PM   #13
Turn the key to ON(II) and then check for voltage to body ground at the Yel wire terminal in the unplugged hazard switch connector.
Old 09-16-2011, 11:55 AM   #14
cevax's Avatar
On the hazard switch there is a red and yellow wire. I get .62 on onII to ground. With the switch plugged in and hazards on it fluctuates between 14volts to 0 to body ground
cevax is offline
Old 09-16-2011, 12:21 PM   #15
If with the key turned to ON(II) the Yel wire terminal in the unplugged hazard switch connector does not have battery voltage, then the Yel wire is broken somewhere between fuse 15 or the hazard switch connector is bad.
Old 09-16-2011, 01:01 PM   #16
cevax's Avatar
hmm one sec, I will take some photos and post them
cevax is offline
Old 09-16-2011, 01:33 PM   #17
The Yel wire in the hazard switch connector pins to terminal F in the switch:
Old 09-16-2011, 03:25 PM   #18
cevax's Avatar
Again man thanks for the help this is like the fourth time you help me out
Here is my hazard switch
There is no yellow wire there but I figured I try to find it. So I pulled the trimming of the column and found a yellow wire on the wiper stalk
So I figured if that is the wire that controls all of this then it shouldn't be there..
So I pulled it off and put it on the other side and WOLA!!
THANKS MAN!
cevax is offline
Old 09-16-2011, 07:09 PM   #19
So let me get this straight, you were able to plug in the socket connector into the wiper stalk instead of the headlight/turn signal stalk? Please clarify this for everyone for future reference.
fleabag is offline
Old 09-16-2011, 07:24 PM   #20
cevax's Avatar
yup, look at the photo it goes right in there, and wipers/hazards still worked
cevax is offline
Old 09-16-2011, 08:22 PM   #21
99civ's Avatar
lol so who had it plugged into the wrong place? I'm one step worse than you... I have no hazards and no turn signals! I will post a thread one day but I'm not worried now(hatch will be garaged soon).
99civ is offline
Old 09-17-2011, 06:53 AM   #22
cevax's Avatar
It happened when the harness was replaced, doesn't help that almost all honda plugs are the same
cevax is offline
Old 09-19-2011, 08:48 PM   #23
Not sure if it might help, but try replacing the turn signal sockets. What happened to me was that my passenger turn signal would blink very fast when the headlights were off and not blink at all with them on, so I replaced the socket (about $15/each at Honda) and it works good now like it should
lxdriver is offline
Old 05-25-2014, 11:05 AM   #24
Hi, I know this post is very old, but I was reading your post. You had mistakenly plug the wrong plug to the wrong stalk. so that mean, when you turn on your wipers, your turn signal flashes?
THANKS MAN!
darkside59 is offline
Old 05-25-2014, 12:38 PM   #25
Please don't bump old threads for no reason.
Closed Thread
Z6 intake manifold for sale cevax For Sale 9 11-03-2012 11:39 PM
Cxracing turbo manifold cevax For Sale 0 09-30-2012 09:39 AM
Free VC, BWR tiebar, z6/y8 manifold cevax For Sale 1 09-17-2012 08:10 AM
Garrett 57 trim, IM & P28 ETC cevax For Sale 4 07-06-2012 06:51 PM
5 bolt 2.5 inch downpipe cevax For Sale 0 02-24-2012 03:54 PM
Tags
94, blinker, blinking, civic, cx, dont, hazard, hazards, honda, lights, problem, signal, signals, turn, work, working
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
