NO reading failed E-check
Old 07-01-2013, 12:44 PM
nightridder1986's Avatar
Default NO reading failed E-check
I have a 97 Honda civic with a D16Z6 engine swap
took it to e-check here in Ohio
passed everything but my NO
was 2671.2 PPM allowable is 749
I have a header on it with a cold air intake and a high flow cat
Was looking for some hints on how to fix this problem any imput would be helpful thank you
Old 07-01-2013, 12:47 PM
The Grumpiest
grumblemarc's Avatar
Default Re: NO reading failed E-check
High flow cat=test pipe?
Old 07-01-2013, 12:58 PM
no they put a sensor into the muffler
Old 07-01-2013, 01:03 PM
The Grumpiest
Erm? Is your cat a TRUE high flow cat or is it one of the ones pictured here that they only say is a high flow cat?
Old 07-01-2013, 01:09 PM
http://www.summitracing.com/parts/mpe-94109/overview/
this is the one that's on the car
Old 07-01-2013, 01:11 PM
Former User's Avatar
What were HC readings? Were they low?
High NOx also can be caused by the engine running lean or hot.
Old 07-01-2013, 01:14 PM
the HC were 58.3 allowed is 97
CO 0% allowed 0.54%
CO2 28.5
and yes I have been reading and know its a lean or hot condition was looking for some tips on how to fix it with the modifications I have on my car
Old 07-01-2013, 01:16 PM
Well, is the engine running hot? If not, start by checking the ignition timing and replacing the fuel filter.
Old 07-01-2013, 01:17 PM
engine is not running hot.
do you know what the timing should be set at? how many degrees?
Old 07-01-2013, 01:18 PM
See FAQs sticky for diagram.
Have you already replaced the fuel filter?
Old 07-01-2013, 01:20 PM
purgat0ry's Avatar
Are you importing the car into ohio?
Otherwise we don't have emissions testing here... not that it solves your problem, I'm just confused as to why you'd need to do this in OH.
Old 07-01-2013, 01:22 PM
not all counties in Ohio have E-check I live in one that does
DFWRSXS
20
01-08-2006 05:13 PM
_gurusan_
05-05-2005 12:04 PM
zseeanz
04-16-2004 06:55 PM
Weston
06-07-2002 11:12 AM
Quick Reply: NO reading failed E-check
