no brake light***
no brake light***
1999 civic cx hatch
all three brake lights isnt working
i checked all the bulbs they all work when i turn on my car with my headlights and parking lights. but when i step on the brake...not a thing.
im thinking its a fuse. so if it is show me where and what fuse to change..
thanks
thanks
*******no brake light!!
1999 civic cx hatch
thanks.
thanks.
you do know that the brake lights are a seperate part of the bulb than the park lights right?
headlights/parklights - low part of bulb
brake lights - high part of bulb
the brake lights fuse for a 99 hatch is in the under hood fuse box. 15amp (if your horn works that's not the problem)
Re: (Relic1)
There is a pin switch above your brake pedal that activates the lights when you press the pedal. If all three brake lights aren't working, you should check that the switch is working. They can go bad or come unmounted.
id say the thing...that switch on the brake pedal...
that button probably got stuck...its suppose to come out when you step on the brakes..check it out...
that might be bad....or the wirings are loose...
or maybe disconnected....
play with it...the button...
have someone look at your tail light see if the light comes on....
the only thing i can tell you is..
if its not the fuse...the bulb...the wirings...
thats should be it...that switch...try and replace it..go to the junkyard and get one...
Tommay
06-21-2012 03:48 PM
