New battery. Car still won't start! - Honda-Tech
Old 02-24-2007, 11:47 PM   #1
nighttrain33's Avatar
Default New battery. Car still won't start!
Well, as some of you know, my car was broken into and some stuff taken, but only stereo equipment. I pulled the car into my garage and have not started it since (the week before Christmas). I tried starting it a few times, but got nothing electicity-wise. I replaced the battery, and everything works now, but the car won't start. It started fine when I stopped driving it, but now it won't turn over at all.
So....I am thinking it is the starter. Can I get an amen?
-Shane
nighttrain33 is offline   Reply With Quote
Old 02-24-2007, 11:56 PM   #2
sal
sal's Avatar
Default Re: New battery. Car still won't start! (nighttrain33)
Amen brotha
Does the starter even try... do you hear any clicks or noises coming from it. Maybe try and give it a love tap with the butt end of a screwdriver. Sometimes that frees it up.
sal is offline   Reply With Quote
Old 02-25-2007, 12:05 AM   #3
S2k Hybrid's Avatar
Default Re: New battery. Car still won't start! (sal)
My friends car had a starter problem, his dad used to tap it with and it would start right up
S2k Hybrid is offline   Reply With Quote
Old 02-25-2007, 12:09 AM   #4
fmrprojects's Avatar
Default Re: New battery. Car still won't start! (S2k Hybrid)
push start it
fmrprojects is offline   Reply With Quote
Old 02-25-2007, 12:15 AM   #5
Default Re: New battery. Car still won't start! (fmrprojects)
When I turn the hey to the start position, I get one click, and that's it. Like I said, that used to happen every once in a while, but after a few tries, it would start up. Now, I turn the key 10-20 times, with only a click, but no start.
-Shane
Old 02-25-2007, 08:41 AM   #6
ttk3's Avatar
Make sure your cables have good solid connections to the battery. If there's a lot of corrosion built up around the terminals, it could short out the start. Happened on my Taurus all the time.
ttk3 is offline   Reply With Quote
Old 02-25-2007, 09:19 AM   #7
cambopheonix56's Avatar
Default Re: New battery. Car still won't start! (ttk3)
Yes try to hit the starter.
cambopheonix56 is offline   Reply With Quote
Old 02-25-2007, 09:37 AM   #8
rarejdmkid's Avatar
aymen.. tweak the starter.. or replace it..
rarejdmkid is offline   Reply With Quote
Old 02-25-2007, 09:41 AM   #9
instrument's Avatar
like that guy said, if it's a stick push start it.
also if you turn the key and it makes no sounds check your grounds, i'm not sure what was stolen out of it...
instrument is offline   Reply With Quote
Old 02-25-2007, 09:45 AM   #10
GYChris's Avatar
if it just clicks when you turn the key its def the starter, no doubt. but if it makes no noises at all check your grounds.
i had that same problem a while back it would click and not start every once in a while then a couple more tried it would start. eventually it just started clicking every time and not starting so i had to replace it and tada...
GYChris is offline   Reply With Quote
Old 02-25-2007, 09:10 PM   #11
Default Re: (slowEGchris)
Thanks for the replys everyone! As far as push starting it, I don't need to drive it, I have the 4x4 Sierra, I am just trying to make sure that it is indeed the starter that needs to be replaced. As I stated, that was what I thought, and it looks as though that is the problem. Maybe I will replace it when it starts to get warm [in Michigan that is].
-Shane
94 accord won't start oil and battery lights stays on hondamyheart Honda Accord (1990 - 2002) 9 06-18-2016 04:42 AM
Car won't start mariposa921 Honda Element & CR-V 2 09-18-2012 05:31 PM
My 50A hood IG fuse keeps blowing aLaZeE Honda Civic / Del Sol (1992 - 2000) 0 08-09-2012 12:06 PM
Car won't start, Battery or Starter problem? SupaFly_Honda Tech / Misc 3 02-22-2005 08:45 PM
replace crank pulley and car won't start. accordinglyevil Honda Accord (1990 - 2002) 4 01-11-2005 08:46 PM
Tags
2000, 2004, 2006, 2007, battery, car, civic, good, honda, r1, replace, replaced, start, stolen, thinks, won, wont, yamaha
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
