NEED HELP!! Y8 MANI!! NO MASS AIR FLOW SENSOR??
i bought a y8 mani from ebay and it just got here today, it doesnt have a spot for the masss air flow sensor! WHY???? dont i need that? its going on a d15b7
Re: (91civicDXdude)
oh i thought that was what its called, its the sensor right behind the manifold, that have 2 crews holding it in and a screen in the middle of it with matches up to a hole in the mani, the d15b7 had a spot for it.
Re: (torqueless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torqueless »</TD></TR><TR><TD CLASS="quote">ya its from an auto.. so auto y8 mani wont work? what doews iavc stand for?
Idle Air Control Valve, and yes, you need it. Your only options are to drill and tap the bosses on the back of the manifold to accept the IACV, or get a manual Y8 manifold.
Re: (torqueless)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by torqueless »</TD></TR><TR><TD CLASS="quote">urrggghh! a 99 y8 mani (manual) wont fit! WHAT YEARS WILL FIT??</TD></TR></TABLE>
How does it not fit? It should.
Re: (torqueless)
yeah the 99 will fit it just has some extra holes you need to plug at the end of each runner for the cold start assist and one or two nipples you need to cap off.
Ideally you want a 96-98 manual y8 intake those are pretty much a straight bolt on.
Re: NEED HELP!! Y8 MANI!! NO MASS AIR FLOW SENSOR?? (torqueless)
Re: NEED HELP!! Y8 MANI!! NO MASS AIR FLOW SENSOR?? (kkim)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jizzmaster Zero »</TD></TR><TR><TD CLASS="quote">
How does it not fit? It should.</TD></TR></TABLE>
its hard to explain, it matches the studs to the head but it wont sit flush against the head. the bottom of the runners are to tall and it hits a little ridge on the head.
Wes90civic
10
01-18-2004 12:35 PM
