Need help or wiring diagram for 98 Civic stereo - Honda-Tech
Old 11-15-2010, 02:50 AM   #1
Nooch's Avatar
Default Need help or wiring diagram for 98 Civic stereo
I need a wiring diagram for the stock radio in a 1998 honda civic hatchback dx. I recently bought a new headunit and I need to depin/repin the new connectors. Unless someone else knows an easier way to do this.
This is my first time changing a headunit on any vehicle amazingly. hah.
Both connectors are NOT the same either.
Nooch is offline   Reply With Quote
Old 11-15-2010, 03:01 AM   #2
Default Re: I need a wiring diagram or help for an EK.
cut the original plug of the car and splice in the new one
First.EG is offline   Reply With Quote
Old 11-15-2010, 03:20 AM   #3
O.G. triple O.G.
NVturbo's Avatar
....so you bought an aftermarket headunit or a stock one? If it's an aftermarket, get one of those radio harness (Metra) from your local Walmart. If you're trying to install a factory Honda/Acura radio, Metra has car harness wires as well....
DO NOT CUT THE FACTORY RADIO PLUG . You will regret it later.
NVturbo is offline   Reply With Quote
Old 11-15-2010, 05:55 AM   #4
Default Re: Need help or wiring diagram for 98 Civic stereo
Former User is offline   Reply With Quote
Old 11-15-2010, 12:09 PM   #5
Nooch's Avatar
It's an aftermarket one. Specifically a Sony GT250MP, the connectors are different clips. So I was wondering do I depin the old one and repin it into the new plug or am I supposed to get an adapter for them to connect? I just realized that the two connectors are probably using different size metal clips to connect within the clip. Aw ****. I'll check out walmart haha.
Old 11-15-2010, 12:27 PM   #6
H-T White Ops
NOFX's Avatar
I just get an adapter from my local car audio shop.
NOFX is offline   Reply With Quote
Old 11-15-2010, 01:11 PM   #7
Nooch's Avatar
Ya, I guess I'll have to do that or hit up Fry's. Walmart didn't have the right one, only for BOSE headunits. Wish this wasn't so stupid, gotta make **** more plug & play.
Old 11-15-2010, 02:11 PM   #8
The Grumpiest
grumblemarc's Avatar
You need one of these.
http://motors.shop.ebay.com/i.html?_...506.m270.l1313
DO NOT cut or de-pin anything. I've been using these for 15+ years.
grumblemarc is offline   Reply With Quote
Old 08-14-2011, 10:15 PM   #9
Cool and thanks for the quick rreply.Lespaul
Lespaul is offline   Reply With Quote
Old 08-14-2011, 10:27 PM   #10
OK here goes... 98 Civic, removed radio, took radio apart, desoldered "incremental mechanical rotary encoder"...pot was so much easier to refer to a volume control back in the day!
Five pins. Two pins (momentary on/off) one side, Three pins opposite side + two anchor pins middle. ALPS & JAPAN only words stamped backside of switch. Circuit board has VR401 where that part goes to but no part #. Where/Who can I talk to to obtain this little bit of "hell" LesPaul
Old 08-14-2011, 10:37 PM   #11
Before the eyelids close...could someone post wiring schematic (the guts...inside) for AM/FM 98 Civic. Hope voltage/amp max loads are included for the volume control (i.m.r. encoder) Thanks...Les Paul
Old 08-15-2011, 03:38 AM   #12
virgineg6's Avatar
Dont know if you noticed this but this thread is almost a year old, you should just start your own thread instead of bringing them back
virgineg6 is offline   Reply With Quote
Old 08-19-2011, 05:15 AM   #13
Last year, I did cut and soldered to put Pioneer in. It's very hard work take an hour to done this job. Get the harness is the best way.
charnrin is offline   Reply With Quote
Old 08-19-2011, 05:17 AM   #14
virgineg6's Avatar
Wow!!
91 DX Hatch Schematic/ Diagram carlos1890 Honda CRX / EF Civic (1988 - 1991) 0 06-28-2012 03:49 PM
headunit wiring jdmcivicsi522 Honda CRX / EF Civic (1988 - 1991) 1 04-18-2006 09:35 AM
accord 2000 lx radio problems. casmello Honda Accord (1990 - 2002) 4 12-02-2004 09:42 AM
connector question ilikemyaccord Audio / Security / Video 3 08-13-2004 11:37 PM
96 Accord ECU wiring diagram needed tirechirp Honda Accord (1990 - 2002) 2 06-23-2003 03:19 PM
Tags
98, 99, adapter, civic, dash, diagram, diagramr, dx, element, factory, head, honda, radio, stereo, unit, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
