need help on wiring...
i want to make my brake light show turn signals. most of thje new cars come like this now.
each taillight has two bulbs for brake lights, i just want to use the outer ones for turn,
basicaly when i engage left turn signal and brake at the same time my right tails are both red, but left inner is red outer is flashing. i know its possible so i dont need any post that its impossible, i just need the diagram how to connect the trailer light converter in to the civic circuit, also do i need 1 or 2 flashers?
thanks
thanks
Re: need help on wiring...
maybe i am misunderstanding
you want your outer tail to flash with blinker, and your inner tail to be brake light?
i thought that was how stock is?
im not at work but i can pull up a diagram for you if you can explain it a little better to me. sorry i cant grasp the concept right now
R666 has it right....
all you need to do, is splice the turn signal wire into the brake light that you want to flash & it should only flash when the signal is activated & act as a regular brake light any other time...
just tried it out and it didnt work, when i spliced it, the brake work but when i turn the signal all the brake lights start flashing.
