Need help! Overheating but not?
Old 10-01-2005, 03:10 PM
silvsrt4's Avatar
Default Need help! Overheating but not?
Ok this may be long but I need some help or something :-P
The story is the guy that had this 93 civic dx before me blew the headgasket. He had it replaced along with a new water pump, timing belt, alternator, battery, radiator etc. This was about a month ago.
I drove it around last night. All was fine! I drove it about 50 some miles and mostly city driving.
Today I drove it on a 3.5 hour trip going between 75mph-85mph. The Temp gauge needle stayed at about 25%. Then soon as I pulled off the interstate and sat at a light for 4 minutes the temp gauge jumped all the way up to above H!!!! I immediately pulled over and shut the engine off. Opened the hood.... and nothing. No steam no smoke. I could touch the radiator cap with my fingers for about 3-4 secs and then it got a little warm. Opened the radiator cap and no steam. Opened the oil cap and no steam. But I did notice that the radiator reserve canister was way way above max, almost near the top and that some had sprayed out the top.
I let the car cool and drove about another 8 miles with a few lights and the gauge stayed at 25% again. I pulled into the parking space and the needle again climbed to about 75% and then slowly crept to H. I left the car running and poped the hood and the radiator cap was cool to the touch and no smoke or steam coming from the oil cap. Pulled the dipstick and the oil level was between the two dots.
The radiator fan runs and everything looks fine. Anyone have any clues? Where does the temp gauge measure from? Whats the problem!!! ahhhh
Thanks All
BTW the cluster may be bad because I replaced the VSS and it made the speedometer start working but then it craped out last night late. And then today it started working once I hit 60mph and then it never stopped working all the way to Kentucky and still is currently working. So maybe the cluster is bad? But I dont think so with antifreeze sprayin a little out of the reserve tank. Just extra INFO.
Old 10-01-2005, 04:11 PM
ProJectCvic's Avatar
Default Re: Need help! Overheating but not? (silvsrt4)
are the fins on your radiator all mesh up? If this is so, air coming from your fan is insufficient to cool down your radiator.
Old 10-01-2005, 04:14 PM
silvsrt4's Avatar
The radiator is brand new...
Old 10-01-2005, 04:24 PM
MugenHonda's Avatar
Location: With my POS D15B2, Whereever whenever, United States
Default Re: (silvsrt4)
change the thermostat
it is getting stuck
thats why when you get off the highway, less air it overheats automatically
As long as your fans turn on, it is the thermostat
easy 10 dollar fix
Old 10-01-2005, 04:25 PM
silvsrt4's Avatar
Is it still the thermostat if the reserve canister is way above max now, it sprayed a little... and if I remember correctly. The top hose was hot and the bottom was cold.
cadwiese
01-06-2012 06:51 PM
mrtoser
17
07-27-2011 08:51 PM
mullenium
09-05-2008 02:03 PM
88EFhatch
07-12-2005 05:48 PM
HX_Guy
09-02-2001 07:37 PM
Quick Reply: Need help! Overheating but not?
