NEED HELP with obdII codes
Old 07-13-2008, 10:40 PM
darksolguy's Avatar
Default NEED HELP with obdII codes
ok.... my car is obd2 and it throws a check engine of 54 but i think thats for the obd1 cars and mine is obd2... can anyone tell me whats the code for obd2 and what it means.. thans.. by the way its a sohc vtec .. and stock ecu.. thanx
Old 07-14-2008, 02:15 PM
H-T White Ops
NOFX's Avatar
I might as well add this info to the thread for others.
These are both for '96-'00 Civics (these match to the MIL flash code of 54):
P1336
Detection Item: Crankshaft Speed Fluctuation Sensor Intermittent Interruption
Probable Causes: CKF sensor
P1337
Detection Item: Crankshaft Speed Fluctuation Sensor No Signal
Probable Causes: CKF sensor; CKF sensor circuit; ECM/PCM
Old 07-14-2008, 05:24 PM
darksolguy's Avatar
Default Re: (NOFX)
thanx very helpful
Old 07-14-2008, 05:57 PM
abusedhusband's Avatar
Default Re: (darksolguy)
i see alot of the time for this code is that the crank sensor wire slips out of th e timing cover clip and rubs the alternator belt and ruins the wire. replace the crank sensor and your problem should be fixed.
Old 07-14-2008, 05:58 PM
Former User's Avatar
Based on information in the manual, this sensor functions primarily to detect engine misfiring.
Old 07-14-2008, 06:00 PM
darksolguy's Avatar
Default Re: (abusedhusband)
i barely changed the sensor b4 i swapped in the motor.. but the plug from the engine harnes got cut and i lost the plug so i used a diff plug with diff colors and i didnt knoe what wire went where.. the colors are white brown and black in what order do they go... right now i have them white black brown
Old 07-14-2008, 06:05 PM
Old 07-14-2008, 06:16 PM
darksolguy's Avatar
Default Re: (RonJ@HT)
so the black one goes in the middle
Old 07-14-2008, 06:17 PM
darksolguy's Avatar
Default Re: NEED HELP with obdII codes (darksolguy)
would this do the trick/?
https://honda-tech.com/zerothread/2342437
Old 07-14-2008, 06:18 PM
"so the black one goes in the middle"
Yes, by default.
Old 07-14-2008, 06:19 PM
darksolguy's Avatar
but if i do this would this prevent me from passing the reff?
EFjoe91
12-28-2010 01:36 PM
AMseven
Honda Civic (2001 - 2005)
09-22-2009 08:37 AM
cnydc2
07-23-2009 12:44 PM
satan_srv
04-15-2003 06:44 PM
Quick Reply: NEED HELP with obdII codes
