need help how to remove front windshield window?
Old 11-11-2006, 10:54 AM
dylokjai's Avatar
Default need help how to remove front windshield window?
some freaken babies shot up my front windshield now it has 3 pellet holes ready to shatter all over me when i drive behind a trucker...anyways i have a window from my wreck coupe and was just wondering how to remove it i took off all them pop up thingy and screws wipers and the trims now how to remove the window?
Old 11-11-2006, 12:59 PM
Darth ModerVader
Padawan's Avatar
Default Re: need help how to remove front windshield window? (dylokjai)
Windshield installation is something that should be left to an experienced installer (preferably a professional). It isn't something you should be doing yourself, as it is a very important safety item.
Old 11-11-2006, 02:47 PM
k20EP3's Avatar
Default Re: need help how to remove front windshield window? (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">Windshield installation is something that should be left to an experienced installer (preferably a professional). It isn't something you should be doing yourself, as it is a very important safety item. </TD></TR></TABLE>
I agree 100% with ^^^^^^ dont mess with it if you have to ask about it on here.
Old 11-11-2006, 03:02 PM
NonovUrbizniz's Avatar
Default Re: need help how to remove front windshield window? (k20EP3)
I don't know a single mechanic that would change a windshield themselves...
Forget safety item... if it leaks your life sucks... if it breaks your life SUCKS....
But fyi...
Remove outside trim around windshield and use a guitar string or any thin strong wire to break the seal from the sealer. Go around the whole outside edge of the windshield in a see-sawing motion... it's generally easier to do this with 2 people as there are going to be spots where you can't reach the outside and the inside at the same time.
Then remover the old windshield...
Clean off the area of all previous sealer, apply new sealer, follow instructions on sealer container as far as letting it set or not... install new windshield...
There may be some tabs holding down or aligning the windshield but you'll figure that out when you take out the old one...
Then generally people will tape part or all of the seam to ensure the glass gets held into the sealer well and that dirt/debri/water don't get onto the sealer while it's curing... although it's own weight does most of the work as far as holding it down goes.
Again... a civic windshield installed is generally at or under 200 bucks... I'd just pay to get it done.
JDM_Frijoles
17
04-19-2007 11:28 AM
ekcivic9
12-24-2005 06:50 PM
athoughts
11-28-2005 04:47 PM
renegadez7o7
09-06-2005 10:40 PM
CivicRaping
03-21-2005 12:07 AM
Quick Reply: need help how to remove front windshield window?
