Need help with codes!
Old 01-30-2008, 09:38 PM
ek-g6's Avatar
Default Need help with codes!
I threw some codes on my friends 99 civic ex automatic, and these codes came up:
p1298- Electric load dectector (ELD) circuit high voltage.
p0135- o2 sensor
p0141- o2 sensor
p1768- problem in torque converter clutch solenoid valve b.
I know i can get new o2 sensors right away, but what the heck is an Electric load detector? Also what the heck is a torque converter clutch solenoid valve b? Can both be replaced? I've searched and had no luck in finding answers. any help would be appreciated. thanks in advance.
Old 01-30-2008, 09:47 PM
boostedjdmdc2's Avatar
when i look up p1768 it comes back as a problem with the linear solenoid
Old 01-30-2008, 09:51 PM
and you can replace that if thats what it is
Old 01-30-2008, 09:55 PM
oh and with the p1298 is the car blowing any fuses or anything?
Old 01-30-2008, 09:56 PM
ek-g6's Avatar
Default Re: (boostedjdmdc2)
no checked all the fuses, all are still good, what is a linear solenoid? do you have a picture?
Old 01-30-2008, 10:04 PM
surely, post one in a sec
Old 01-30-2008, 10:05 PM
ek-g6's Avatar
thanks..also where is the Electronic Load Detector located at? would you also happen to have a picture of the ELD?
Old 01-30-2008, 10:06 PM
Default Re: (ek-g6)
Old 01-30-2008, 10:10 PM
actually that might not be the right pic let me double check that
edit: yah that one posted above isnt the EXACT solenoid and location but thats what it looks like, ill try to find one better suiting the code
Old 01-30-2008, 10:19 PM
ek-g6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedjdmdc2 &raquo;</TD></TR><TR><TD CLASS="quote">actually that might not be the right pic let me double check that
edit: yah that one posted above isnt the EXACT solenoid and location but thats what it looks like, ill try to find one better suiting the code</TD></TR></TABLE>
I was trying to look for the exact spot that it is bolted on to. Could that be the cause of my friend's car not starting. i know that it is getting fuel and spark, but it wont turn over.
luckydogie
Honda CR-V & Element
04-06-2014 09:32 AM
broncoman74
11-25-2007 06:42 AM
Aquafina
04-01-2007 12:43 AM
longhair77
06-23-2006 11:00 AM
eholde
02-07-2006 07:56 AM
Quick Reply: Need help with codes!
