Need Help! Can loose intake manifold cause car not to start? - Honda-Tech
Old 02-03-2007, 06:51 PM   #1
CSHornet60's Avatar
Default Need Help! Can loose intake manifold cause car not to start?
Hello everyone! I Need Help! Can a loose intake manifold cause my car not to start? Im waiting for the rest of my bolts from honda to arrive but in the mean time i have tried to start my car in the mean time but it doesn't start. I have fuel and Spark. Any suggestions? Thanks!!
CSHornet60 is offline   Reply With Quote
Old 02-03-2007, 06:57 PM   #2
mafia's Avatar
Default Re: Need Help! Can loose intake manifold cause car not to start? (CSHornet60)
it cranks?
mafia is offline   Reply With Quote
Old 02-04-2007, 11:29 PM   #3
CSHornet60's Avatar
Default Re: Need Help! Can loose intake manifold cause car not to start? (mafia)
Yep it cranks. Could there be a lose of air flow that causes the engine to not start?
Old 02-05-2007, 09:10 AM   #4
mafia's Avatar
I dono, i had something like that on a 94 integra, and idle was at 4k Rpms.. (it had all nuts on, but some were loose.) But it started. Any gas leak from I/M?
Old 02-05-2007, 09:49 AM   #5
sql_civic's Avatar
Got any ground wires going to the IM bolts? Normally you shouldn't.
Got any other loose bolts like on your thermostat housing where your engine harness ground is located?
sql_civic is offline   Reply With Quote
Old 02-05-2007, 10:21 AM   #6
medside's Avatar
Default Re: Need Help! Can loose intake manifold cause car not to start? (sql_civic)
a loose intake manifold should not cause you not to start, your idle is going to be off and may even jump up and down.
medside is offline   Reply With Quote
Old 02-08-2007, 04:57 AM   #7
hondasniper's Avatar
like sql_civic said, check to make sure that your grounds are connected. check to see if you have spark and fuel (turn the motor over w/o the spark plugs in to see if you see a mist of fuel coming out from the spark plug holes). then start looking for blown fuses.
hondasniper is offline   Reply With Quote
Old 02-08-2007, 08:56 AM   #8
instrument's Avatar
why are you waiting on honda for bolts?
you do realize that honda doesn't make some sort of super bolt that no one has reverse engineered dont you?
instrument is offline   Reply With Quote
Old 02-08-2007, 10:32 AM   #9
doubledeucehatch's Avatar
Default Re: Need Help! Can loose intake manifold cause car not to start? (medside)
Quote:
Ya it will sound like your IACV.
doubledeucehatch is offline   Reply With Quote
Question on Loose shifter GuCBlackEk Honda Civic / Del Sol (1992 - 2000) 5 04-07-2010 04:28 PM
How to check if T-belt has jumped a tooth? (D16Z6) rasinhell Tech / Misc 4 09-11-2005 07:20 PM
HELP!!!! INTEGRA WON'T START!!! pu5sipoppr Acura Integra 12 07-30-2005 02:21 AM
HELP!!! brake problem! GumballNA Tech / Misc 1 08-01-2003 07:10 AM
DO I NEED THIS!!!!!!!!!11 TurboBumblBee Honda Civic / Del Sol (1992 - 2000) 2 03-07-2002 05:26 PM
Tags
car, caus, civic, d16, engine, honda, housing, intake, leak, loose, manifold, run, spark, start, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
