need help burning oil - Honda-Tech
Old 03-18-2017, 07:08 PM   #1
Default need help burning oil
Hey I need help I'm losing oil and no leaks or smoke so I don't know what to do any ideas please help
Christopher26 is offline   Reply With Quote
Old 03-19-2017, 05:35 AM   #2
Default Re: need help burning oil
Quote:
How much per day or week or month? Some loss is normal. How many miles on motor?
Have someone follow while you drive and ask them to look for dark blueish smoke from exhaust when you fast accelerate and decelerate.
Read this: https://www.amsoil.com/techservicesb...onsumption.pdf
Did you thoroughly clean the engine, cover with baby powder and inspect for leaks?
Using conventional or synthetic oil?
Last time PCV valve inspected/replaced?
Jimi Hondrix is offline   Reply With Quote
Old 03-19-2017, 07:05 AM   #3
Well burned it all off in a month and it's rebuilt 23000 miles
Old 03-19-2017, 08:54 AM   #4
Intelligently Stupid
TomCat39's Avatar
This doesn't specify how much has burned off in a month or even the distance travelled for the burn off.
Honda spec states the car can burn up to 1 liter of oil every 1500 kilometers before it's considered a problem.
It sounds to me like a proper break in procedure was not done upon rebuild. The car was likely babied too much immediately after rebuild when it should have been put through it's paces.
Pulled from motoman (my favored method):
Step 1Do three cyclesRedline 6500Redline 7200Redline 8400
1st40% RPM to 60% RPM at half throttle2600 RPM - 3900 RPM2880 RPM - 4320 RPM3360 RPM - 5040 RPM
cycle60% RPM back to 40% RPM at zero throttle (Do not use the brake!)3900 RPM - 2600 RPM4320 RPM - 2880 RPM5040 RPM - 3360 RPM
2nd40% RPM to 60% RPM at half throttle2600 RPM - 3900 RPM2880 RPM - 4320 RPM3360 RPM - 5040 RPM
3rd40% RPM to 60% RPM at half throttle2600 RPM - 3900 RPM2880 RPM - 4320 RPM3360 RPM - 5040 RPM
 If done on dyno, allow 15 minutes to cool engine before doing step 2
Step 2Do three cycles
1st40% RPM to 80% RPM at 3/4 throttle2600 RPM - 5200 RPM2880 RPM - 5760 RPM3360 RPM - 6720 RPM
cycle80% RPM to 40% RPM at zero throttle (Do not use the brake!)5200 RPM - 2600 RPM5760 RPM - 2880 RPM6720 RPM - 3360 RPM
2nd40% RPM to 80% RPM at 3/4 throttle2600 RPM - 5200 RPM2880 RPM - 5760 RPM3360 RPM - 6720 RPM
3rd40% RPM to 80% RPM at 3/4 throttle2600 RPM - 5200 RPM2880 RPM - 5760 RPM3360 RPM - 6720 RPM
 If done on dyno, allow 15 minutes to cool engine before doing step 3
Step 3Do three cycles
1st30% RPM to 100% RPM at full throttle1950 RPM - 6500 RPM2160 RPM - 7200 RPM2520 RPM - 8400 RPM
cycle100% RPM to 30% RPM at zero throttle (Do not use the brake!)6500 RPM - 1950 RPM7200 RPM - 2160 RPM8400 RPM - 2520 RPM
2nd30% RPM to 100% RPM at full throttle1950 RPM - 6500 RPM2160 RPM - 7200 RPM2520 RPM - 8400 RPM
3rd30% RPM to 100% RPM at full throttle1950 RPM - 6500 RPM2160 RPM - 7200 RPM2520 RPM - 8400 RPM
 If done on dyno, allow 15 minutes to cool engine before doing any more pulls
TomCat39 is offline   Reply With Quote
Old 03-19-2017, 02:31 PM   #5
Is the motor running properly currently? Any knocking or abnormal noises? From my experience with a 2007 Mazda 3 (2,3L) engine which suffered from excessive oil consumption the internals (bearings, crankshaft) tolerances opened past spec and soon after developed rod knock. When I searched online it seems to be an occasional problem with the Ford Duratec 2.3L engine that that generation of Mazda 3's used. The engine had 192k miles on it when it died so I certainly can't say it's a bad engine. This may or may not be the situation with your engine however, if it wasn't rebuilt correctly and spec tolerances weren't adhered to it very well may be the issue. What is the lowest level on the dipstick the oil got down to?
If you are absolutely certain it's burning and not leaking oil (4 quarts in a month) your options are pretty limited and my guess is it won't be long before another rebuild or replacement is in order. First thing is drain oil and inspect the oil for metal particles..if you find metal particles then most likely from worn main bearings. If you don't see metal in oil then to slow burning go up to a thicker viscosity : 40w (weight) oil. You can try Lucas oil stabilizer or similar product. Also, if it's burning that much oil it may clog up the catalytic converter (if not clogged already) If you live in a state that doesn't do inspections you may want to gut the cat (knock screens out) but, it's against federal law regardless of state so, do at your own risk.
Old 03-21-2017, 09:25 AM   #6
Badcopyinc's Avatar
I'm currently burning more oil than i should be but its completely obvious as you cant smell anything but oil if your within 20ft of the car while its idling.
i just did a oil change and put exactly 3.75 quarts in so i can monitor how fast its burning. and im pulling my plugs this evening to see if they show signs of anything.
like jimi said have someone follow you because i haven't specifically noticed smoke until last evening when i really hit the throttle but i only noticed it because there was a car still sitting in the same spot behind me and his headlights lit the small cloud up.
again very very hard to notice through your rear view.
Badcopyinc is offline   Reply With Quote
Old 03-21-2017, 10:39 AM   #7
TomCat39's Avatar
Quote:
And even harder if your windows are tinted int he back like many of our cars are.
First time Honda motor owner , trying to replace oil pan please help Plagues Honda Prelude 1 09-05-2016 11:49 AM
no oil in oil filter!!!HELP! jdm inc Tech / Misc 20 11-19-2009 08:07 PM
b16 turbo - help freeburn Honda Civic / Del Sol (1992 - 2000) 4 03-31-2008 04:29 AM
Stripped Oil Drain Plug Help xlasianizelx Honda Civic / Del Sol (1992 - 2000) 9 10-21-2007 11:34 AM
need help oil pressure ??? Chubs Honda Prelude 1 10-08-2003 03:25 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
  • Ask a Question
What's your question?
Send
