Need Help B16 Transmission Reverse Problem
Here's whats happening, the tranny will go on reverse and it will back up but the instant you try to press the clutch again the car just stops. Its like something is suddenly binding the intant you press the clutch while its moving in reverse. So If I start from a dead stop and try to back up its fine, and then right when i press the clutch again the whole car litterally stops. It does not pop out of gear, there are no grinding noise and it shifts to all gears very smooth. I used honda MT fluid and when i pulled it out i tried spinning the countershaft while the tranny was on reverse and it was really tight. Out of Ideas already, I appreciate any help i can get on this. Thanks
ls-vteccoupe
10-22-2010 08:07 AM
YungD618
14
09-14-2010 09:40 AM
