Need Brake Help ASAP!
Old 07-17-2014, 04:34 PM
deproux's Avatar
Default Need Brake Help ASAP!
So I just recently purchased a '95 Civic EX and it has been dream. Just recently my rear right calipers seized up and it needed replacement. I figured this was a good time to replace my brake setup, so I changed the calipers, rotors, and pads.
Everything went great during the brake replacement until we got to the last caliper we were installing (rear right). The banjo bolt that connects the brake line to the back of the caliper ended up being stripped in the old caliper and we were unable to install the knew caliper. The car sat over night with the one brake line disconnected completely (Later on, I assumed it was leaving that brake line disconnected that completely drained the system of fluid). So the next day we got a replacement banjo bolt and finished the job. Bled the brakes, etc... After bleeding the brakes 4-5 times the pedal was still spongy and would go right to the floor when the car was on. When the car was off the pedal would still build pressure.
I happened to have an OEM brake master cylinder on hand and replaced it just in case there was a bad seal in the 20 year MC. After replacing the MC and bleeding the system multiple times for good measure the pedal is still soft. Builds pressure when car is off, but as soon as it is on the pedal drops. We bled the system another 5-6 times and still have a VERY soft pedal with very light braking power. We have checked all the lines, we checked the ABS system and even bled that. Nothing as been able to restore the brake pedal stiffness.
Does anyone have any experience with a similar problem or any input that can help?
(I have done as much research that can be done on the internet and have come up with no good answer. I see a lot of answers saying replace the MC, but I've done that. I have a spare brake booster as well if that might be the issue)
Let me know what you think!! In dire need of help.
David
Old 07-17-2014, 04:38 PM
The Grumpiest
grumblemarc's Avatar
Default Re: Need Brake Help ASAP!
Did you bleed the brakes in the correct sequence?
Old 07-17-2014, 05:05 PM
yippee-ki-yay
eHMxhACk's Avatar
Did you bench bleed the new MC before installing it?
eH.
Old 07-17-2014, 09:51 PM
O.G. triple O.G.
NVturbo's Avatar
eH.
I likely doubt he did.
Old 07-22-2014, 02:26 PM
deproux's Avatar
Yes, at least I believe I did. I have seen a few sequences people are calling correct. Which one are you referring to for a '95 civic with ABS?
Yes we bench bled it and then bled the brakes some more. I actually drove it around for a couple days because it had firmed up somewhat. We figured that would push some air in the system towards the calipers so when we bled it again we would get most of it. Well we bled it again, and no progress, if anything almost worst. Did a overall pressure check and looked for leaks everywhere.
eH.
kinda douchie
Old 07-22-2014, 02:42 PM
The Grumpiest
You believe you did? Explain the procedure please.
Old 07-22-2014, 02:53 PM
OptimisticWay's Avatar
What 1995 Civic EX comes with ABS and rear disc brakes?
Yeah, bench bleeding the master cylinder and then bleeding the right rear, left rear, right front, and finally left front is the bleeding sequence you would do for a LHD Civic.
Old 07-22-2014, 03:48 PM
yippee-ki-yay
eHMxhACk's Avatar
I believe any 92-95 EX with optional ABS came with rear disc. I've pulled calipers (and brackets) from a 1994 EX.
eH.
Old 07-22-2014, 03:55 PM
#1 Super Guy
94eg!'s Avatar
Straight from the 94 OEM Shop manual (with or without ABS)...
1 RR
2 LF
3 LR
4 RF
It goes in an X pattern because the braking system is divided into two separate circuits, and you have to do them one at a time.
In the USA, all EG's with ABS came with rear discs. In 1995 this includes the EX 2dr ABS, EX 4dr ABS, LX 4dr ABS & Del Sol VTEC. In 1994 there was also an Si 3dr ABS (but the Del Sol VTEC didn't have ABS that year). In 1992 there was no 2 doors coupes or del sols.
Old 07-22-2014, 03:56 PM
yippee-ki-yay
eHMxhACk's Avatar
... then bleeding the right rear, left rear, right front, and finally left front is the bleeding sequence you would do for a LHD Civic.
No, it isn't.
eH.
Old 07-22-2014, 04:03 PM
#1 Super Guy
94eg!'s Avatar
Beat you to it.
Old 07-22-2014, 04:23 PM
yippee-ki-yay
eHMxhACk's Avatar
Originally Posted by 94eg!
Beat you to it.
Dang it! If it wasn't for the pretty picture, I might have had it!
eH.
Old 07-22-2014, 04:40 PM
1 RR
2 LF
3 LR
4 RF
Ouch, my Chevelle memory told me this. I am glad you told me this. Never knew this about Honda's. I will have to look at some of my manuals. Would love to find one of these abs civics in the junkyard. I suppose an Integra would be the same thing though.
Old 07-22-2014, 04:59 PM
I found this tidbit of info.
https://honda-tech.com/forums/suspension-brakes-54/95-civic-ex-equipped-abs-2856370/
Old 07-24-2014, 12:38 PM
#1 Super Guy
94eg!'s Avatar
The EG ABS system is a 3 channel system. That is it pulses the two front wheels independently, and the two rear rear wheels simultaneously. This means it's not ideal for performance. If you lift a rear tire entering a corner, your ABS system will kick in prematurely and reduce your braking performance.
The 94-97 Integras used this same 3 channel system with the exception of the Type R in 97. The type R had the new 4 channel system that featured a much lighter & simpler combined modulator/accumulator system with a now external proportioning valve (more similar to non abs hondas). The 4 channel system allows for much more accurate modulation of the individual rear wheels. This system was used on all ABS Integras from 98 onward.
This 4-channel system was also introduced in 96 on the EK Civics before the DC2 Type-R came to the US.
Old 07-24-2014, 12:42 PM
Nice, now I know what to look for when I am in the junkyard.
I have an EK-3 VTi engine clip that has ABS on it. It is a 1999 I believe. I wonder what version of ABS this has on it?
Old 07-24-2014, 08:45 PM
#1 Super Guy
94eg!'s Avatar
every civic from 96 onward had 4-channel abs. Your EK definitely has it.
Old 07-25-2014, 06:31 AM
dewey_civic's Avatar
So to clarify this is how all ABS brakes get bled for Honda?
Old 07-25-2014, 07:59 AM
#1 Super Guy
94eg!'s Avatar
No, this is how Honda's old 3-channel ABS (licensed from another company) gets bled. This includes all EG's, Del Sols & 94-97 Integras (except Type-R).
Honda's newer 4-channel ABS system (96+ Civic & 98+ Teg & 97 ITR) all bleed in a different order due to the completely different design of the ABS system. I believe all later Hondas with 4-channel ABS bleed LF, RF, RR, LR. Basically clockwise starting at the Drivers-Front. You should still consult the real shop manual 1st just in case cause I cannot confirm. I know that's the order for my 03 Element, 05 TL & 04 Pilot.
Old 07-26-2014, 06:50 AM
deproux's Avatar
Figured it all out! Thank you for all the help, turns out the rod in the brake booster just needed adjusting. I am occasionally getting a very stiff pedal though, so I think the booster might be on its way out, even though I though those things lasted forever.
Old 07-26-2014, 01:19 PM
ngarover's Avatar
Brakes are not working at all on my 93. Going to replace them and the master cylinder. Any suggested kits?
ndiehm
08-15-2011 08:56 PM
jdmsir4dr
Suspension & Brakes
03-07-2010 01:23 PM
baller862
Honda Civic (2001 - 2005)
12-14-2009 05:41 PM
gh0st32
05-15-2005 08:36 AM
Quick Reply: Need Brake Help ASAP!
