MY VTEC KICS IN BUT NO ACCELERATION
Old 07-07-2011, 07:44 AM
JDM_HNIC's Avatar
Default MY VTEC KICS IN BUT NO ACCELERATION
I have eg6 w/gsr swap OBD-1 i recently did a full tune up (spark plugs, wires, rotor, distributor cap and rotor). After a few days V-TEC kick i mean u can hear it but its not picking up acceleration like it should but drive good until u hit vtec. So I open the distributor and the screw that hold the rotor in place had came out leaving the rotor loose insde the distributor. I put the rotor back on checked the timing and drove and im still having same problem. I have checked the ECU (chipped P06),fuel pressure, leak down test and thats all good. So im woundering if its the distributor is bad because of the loose rotor inside of it. PLEASE HELP
Old 07-07-2011, 07:55 AM
JDM_HNIC's Avatar
Default Re: MY VTEC KICS IN BUT NO ACCELERATION
And also I don't have a check engine light WTF is up.
Old 07-07-2011, 12:11 PM
Cynical 1's Avatar
what are you expecting to happen when "vtec kicks"?
no, really?
Old 07-07-2011, 12:31 PM
kaiba's Avatar
BOOST!
Old 07-07-2011, 03:08 PM
ejoneZC_949's Avatar
Do you have a spare dizzy to test out? Cuz i would starts with that to test it
Old 07-07-2011, 03:54 PM
Gustav129's Avatar
Your not supposed to feel VTEC...
VTEC overlap:
- Setting VTEC Crossover point -VTEC engagement on a stock car is OPTIMIZED. Do NOT mess with it because all you are really doing is taking away power, depsite what it "feels" like.
Now that we have that cleared up...YES, i know that bringing the VTEC crossover up or down around 500 or even 1000 rpm up or down may indeed improve your power curves. Again, this is something u can only really prove if you are on a dyno and u can see the immediate results.
So, why do you need a vtec controller? U don't, really. Unless you are using aftermarket cams, or have upped the compression, or some other internal modification that demands a shift in the VTEC x-over to again be optimized. AGAIN, something you should really be doing on the dyno, as every motor is different, not to mention weather conditions, grade of gasoline, general condition of the motor, etc....
So when you hear people say "I got a vtec controller and I set vtec to 3,000 rpm so im mad fast now", u know they're a not bright.
Why? This leads into my explanation on how vtec works but, basically on a vtec motor there is a vtec cam lobe and non vtec primary & secondary cam lobes. Those non vtec lobes are optimized for low end power delivery. However, @ upper RPM, the small lobes cannot deliver enough air nor keep the valves open long enough to continue to let the motor make power.
Hence, the VTEC crossover...where the VTEC cam lobe takes over duties in opening and closing the valves from the secondary and primary lobes. Since the vtec cam lobe is much taller, it can now provide more air and duration the motor needs to keep making power @ higher RPM.
Now think about it. What does setting VTEC at 3,000 rpm do? It makes a cam lobe designed to work well at HIGH rpm to work at LOW rpm. Conversely, setting VTEC too high will cause the motor to start dying out, then JUMP foward when the VTEC lobes take over.
If u have or do get a vtec controller, try it one day.
Set vtec to 3,000 and see how much of a pig the car is down low. Then set vtec to say 7,500 rpm or something. See how the car accelerates, slows down, then springs foward again at vtec x-over. You may think that is the car making more power, but if you were to look at dyno graphs, you would see the torque curve fall off, then rise back up @ your specified vtec cross over point. The above is also a good way to determine a starting point for an optimal vtec x-over when you have done some internal mods and u would like to set vtec @ a certain point. Take a dyno pull with vtec set low, then another pull with vtec set really high.
Overlap the graphs and where the curves intersect where power falls off and where power comes up is where you should start to mess around with a crossover point. Now, I-VTEC is VTEC, with a twist. Toyota's VVTL-i is the same thing as i-VTEC. Basically, in addition to VTEC, the ECU reads and modifies both intake and exhaust cam timing to an optimal point at every point on the RPM band. This ensures the most efficient cam timing to achieve optimal hp and torque. Infinitely Variable valve Timing and lift Electronic Control. This is why the new RSX-S motors, although only making 5 more hp than the old Type-R motors, are making around 12 more lb-ft of torque - because of i-vtec.
Also realize that VTEC and i-VTEC, although refined and marketed by Honda, is nothing THAT new. I think some Mercedes models first used variable valve timing back in the 50's or 60's...and in today's market, Ferrari, BMW, Toyota, Nissan, Honda, and many other manufacturers use some variation of variable valve timing. If you think about it, although complex and expensive both to research and develop, a variable valve and cam timing system has no competition from a fixed valve timing and fixed cam timing system. Pretty soon, all cars in the market will have variable valve and cam timing, not only does it help with making power, as I'm sure you're all concerned, but since it is more efficient, it cuts down on pollution and smog as well.
Old 07-07-2011, 05:44 PM
owneyboy's Avatar
why CAPTIALIZE VTEC? but like above its not a speed boost. just hope its not rod knock/metal shavings in your oil making your vtec engaging ... vtteeeeCCCC
Old 07-09-2011, 12:53 AM
B18 EG6's Avatar
hahahaha I love reading these "O my V-Tec isnt engaging" threads...they are HILARIOUS!!!! Dude honestly just like I told a guy the other day when he asked me that, if its that big of a deal, just turbo the damn thing.
Old 07-09-2011, 03:23 AM
Resident Gearhead
BryanM.'s Avatar
Explain how you checked it.
What chip and where did you get the ECU?
Old 07-09-2011, 03:25 AM
Resident Gearhead
BryanM.'s Avatar
VTEC
Old 07-09-2011, 04:50 AM
The Grumpiest
grumblemarc's Avatar
Because it's not a regular word, even though most of you somehow think it is.
Variable Valve Timing and Lift Electronic Control
Old 07-09-2011, 05:46 AM
HAMOTORSPORTS's Avatar
I'm assuming the ECU is also converted to VTEC? If not, there's your problem lol
Old 07-09-2011, 08:22 AM
Gustav129's Avatar
Because it's an acronym, that's why all the letters are capitalized. VTEC
But there is no hyphen though LOL.
Old 07-11-2011, 04:23 AM
JDM_HNIC's Avatar
I have tried a different ECU and the same problem now its getting worse. I can floor it and it barely wants to accelerate.
Old 07-11-2011, 04:46 AM
The Grumpiest
I've heard clogged cats can cause this.
Old 07-11-2011, 05:04 AM
Moonraker09's Avatar
as long as you hear mmmmmmmmMMMMBAAAAARRRRRGGGGGG!!!!11111oneoneone, you're good. Don't expect an F-18 afterburner
Old 07-11-2011, 09:16 AM
myjdmsucks's Avatar
clutch.
Old 07-11-2011, 09:25 AM
91inprogress's Avatar
check your oil pressure. and also is it revving up with no accel. or just nothing.
Old 07-11-2011, 11:19 AM
4drferio's Avatar
bumpppp
Old 07-11-2011, 11:39 AM
97dc2ftw's Avatar
This happened to me, when I had a clogged cat.. when vtec engages, does it keep getting louder, when you go into higher rpms..
Old 07-12-2011, 04:50 AM
FrankJones's Avatar
It seems my midrange is flat. is that typical of these engines?
Old 07-12-2011, 05:04 AM
4dohs4mohoes's Avatar
What are you attempting to compare it to? What did you drive before? And how long have you had this car/engine setup?
Old 07-12-2011, 02:06 PM
rhymeshark916's Avatar
1)Run a stock p72 basemap 2)get a know good dizzy
check your clutch/flywheel - clutch isn't grabbing? How old/new?
o2 sensor - How old/new is it? Borrow the tool from Autozone and visually check the o2.
Old 07-12-2011, 02:08 PM
Everyone seem to forget this - what IM are you running? If stock, is your IAB disabled? Then if it is, that's your problem.
Old 07-13-2011, 08:47 AM
LoLoCivic's Avatar
ttt
2000SiAddiction
07-17-2011 03:49 PM
GSRimport
03-24-2004 11:12 PM
Touch
12
04-09-2003 10:35 AM
Quick Reply: MY VTEC KICS IN BUT NO ACCELERATION
