Is my Oxygen sensor bad? - Honda-Tech
Old 12-09-2009, 06:50 PM   #1
butter99's Avatar
Default Is my Oxygen sensor bad?
93 H22a civic exhaust smells like fuel
I smogged my car and barely failed a few hydrocarbons over the limit. Then I had someone weld a cat on to my car with an electric welder. They grounded the unit to the exhaust. Next day I drove smoothly to the smog place and smogged it again. #43 (fuel system malfunction or bad O2) engine light came blinking and i failed horribly. CO 7% and hydrocarbons like 300. So I am dumping lots of fuel.
Do you think these symptoms are caused by a bad oxygen sensor? Whats the best way to test the sensor without replacing it?
butter99 is offline   Reply With Quote
Old 12-09-2009, 07:17 PM   #2
butter99's Avatar
Default Re: Is my Oxygen sensor bad?
bump
Old 12-09-2009, 07:29 PM   #3
Duc_du's Avatar
check youtube i believe there is a way to test the sensor because i saw it not too long ago. i think u need some kind of device though to read it.
Duc_du is offline   Reply With Quote
Old 12-09-2009, 07:48 PM   #4
butter99's Avatar
OK I'll check it out..thx
failed smog 97 civic ex all stock d16 ej8_ Honda Civic / Del Sol (1992 - 2000) 12 05-29-2015 08:23 PM
Help failed smog due to high HC and my timing was retarded! dc4teggiehatch Acura Integra 11 05-04-2008 09:17 AM
failed emissions again :( jchrm80 Tech / Misc 7 10-26-2007 01:53 PM
DIY : Causes of failed smog / emissions tests FuNkDrSpOt Honda Civic / Del Sol (1992 - 2000) 10 12-08-2006 12:55 AM
Failed smog inspection EF_LSVtec Honda CRX / EF Civic (1988 - 1991) 10 07-22-2002 12:23 PM
Tags
02, 2000, bad, caused, civic, honda, hondatech, integra, o2, oxygen, sensor, sensors, signs, symptoms, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
