D16Y8 Into 95 Ex
Old 12-09-2009, 04:49 PM
Jibin's Avatar
Default D16Y8 Into 95 Ex
Hey I was planning on swapping a y8 motor into my 95 ex coupe and I was wondering what I would have to do for everything to run correctly. Also could I use the axles and harness from my d16z6 for the swap?
Old 12-09-2009, 05:13 PM
landon.alder's Avatar
Default Re: D16Y8 Into 95 Ex
What's the point? Its just going to be a lot of extra work to convert it to OBDI when its an OBDII motor. The d16z6 is just as good, might as well stick with it.
Old 12-09-2009, 05:15 PM
Linked's Avatar
their almost the exact same motor
you wanna swap, get an LS B engine
if not, boost your z6, you'd get more bang for your buck
Old 12-09-2009, 05:20 PM
Jibin's Avatar
My z6 is going bad thats why i want to swap the y8. Plus I want to sell the car so I dont want to put a b-series in it if I'm not going to keep.
Old 12-09-2009, 05:25 PM
Linked's Avatar
the z6 is going bad in what way?, it may be fixable so you can save some money
Old 12-09-2009, 05:30 PM
Jibin's Avatar
Its knocking and there is a crack in the tranny.
Old 12-09-2009, 05:33 PM
Linked's Avatar
i dont know much about knocks, some people on here can help you out,
it can be rod knock, in which you can replace the rods,bearings and solve the issue i believe
and depending where the tranny is cracked, you can get a tranny bell housing, clutch housing, or just a new tranny alltogether
but you do wanna swap you can part out your z6 block
Old 12-09-2009, 05:46 PM
-__-'s Avatar
^^yeah sounds like too much work cuz he trying to sell it anyway lol. he would have to rip apart the whole motor!
but Jibin the Y8 motor will fall right in. u can use the obd1 alternator and probably swap the Z6 intake manifold and injectors over because the Y8 obd2 ones wont work with your OBD1 harness.
UNLESS u just get an obd2 engine harness and run a jumper harness to your obd1 ECU.
depends how ur going to go about the swap
Old 12-09-2009, 06:09 PM
Jibin's Avatar
Well I want to be able to use any parts from what I have on my car currently for the swap, so pretty much the way you said it is how the way I want to go. Also could I use my axles?
Old 12-09-2009, 06:25 PM
-__-'s Avatar
yes axles will work fine. linkage and everything will work.
cruspeed^2
07-10-2013 07:52 PM
shytdoode
09-15-2009 10:12 AM
bigturbo
05-08-2009 12:09 PM
civictildeath
05-31-2005 09:03 PM
allmotorEG-SI
15
05-24-2004 09:11 PM
Quick Reply: D16Y8 Into 95 Ex
