my car won't go past 3000 Rpms
Old 10-16-2014, 05:43 PM
Daniel777's Avatar
Default my car won't go past 3000 Rpms
I need help
I have a 94 civic d series
I was driving to work yesterday and I've been loosing power and it won't go past 3000 rpms that was on 3 gear and I shift it to 4th gear and it doesn't want to accelerate and I have no power what could it be my transmission is good and my clutch is also new
I have no idea what it could be I need help like asap please if anyone knows what it could be please help me
Old 10-17-2014, 10:58 AM
7rrivera7's Avatar
Default re: my car won't go past 3000 Rpms
Do you have a solid check engine light?
Old 10-17-2014, 12:33 PM
Loves Tossing Salad
09chaplak's Avatar
Compression test that bad boy
Old 10-17-2014, 12:40 PM
slogfilet's Avatar
Definitely compression check and also check timing. Might have jumped a tooth.
Regardless, do those two tests.
Old 10-17-2014, 09:18 PM
Former User's Avatar
Default Re: my car won't go past 3000 Rpms
Limp mode. Pull the CEL codes.
Old 10-22-2014, 09:33 PM
Daniel777's Avatar
No check engine light on
And I'm going to do the compression test on it tomorrow and the timing test as well
Old 10-23-2014, 03:45 AM
msmernic's Avatar
tps sensor maybe?
Old 10-23-2014, 04:26 AM
Tell us whether the CEL works. Click the codes link in my signature.
Old 10-23-2014, 10:49 PM
Daniel777's Avatar
What is the cel code ??
Old 10-23-2014, 10:50 PM
Daniel777's Avatar
What link ??
Old 10-24-2014, 05:19 AM
Loves Tossing Salad
09chaplak's Avatar
Now I'm confused haha lets get things straightened out before we go any further. Step one, CEL = Check Engine Light. Step two, the link is in Ron's signature. See where it says "don't guess, troubleshoot" in green? And right under there is says useful tech links,the codes one is what he's talking about. If your CEL light is not on, there are no codes. He's saying make sure it works. Does the CEL light turn on for 2-3 seconds then off when the key is turned right before start up, ON(II)? If so, it is apparently working.
OK, continue!
Old 11-22-2014, 11:08 AM
Daniel777's Avatar
The check engine light works it goes on for 2-3 second then it turns off you can hear it
Old 11-22-2014, 11:47 AM
Fish Twig
tony_2018's Avatar
No one ever hears a CEL light come on.
Old 11-22-2014, 04:54 PM
Loves Tossing Salad
09chaplak's Avatar
hahaha turns key on, "Check Engine Light on!" Did you ever do those other tests?
cilvia
08-07-2010 06:09 PM
esoterEK..
10-02-2006 09:56 AM
Spoolin'VW
15
11-19-2005 03:27 PM
EckoTech
09-30-2005 08:43 PM
Quick Reply: my car won't go past 3000 Rpms
