My car acts up @ the gas station?
Every time i fill up my tank my car delays to crank over, or it will start and shutoff quick. Otherwise it never shuts off or anything just when I put gas in it.,even if it has half a tank, filled or not, any gas station it always does it.Its a 99 ek with itr swap.
Re: My car acts up @ the gas station? (jdmmanek)
Sounds to me like a fuel pressure issue. After you fill up make sure the gas cap is turned a few clicks. And before you start the car, turn the key into the "on" position (when all your warning lights on the cluster turn on). Once your seatbelt light goes off, or about 7 seconds later then try to start the car.
After having done all the it SHOULD start up right away.
Banned
Re: My car acts up @ the gas station? (galaxy2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by galaxy2000 »</TD></TR><TR><TD CLASS="quote">i think dat is ur mass airflow senser. go buy one an try it out</TD></TR></TABLE>
Care to explain??
Care to explain??
ur joking right? i sure hope so.
it does sound like a pressure issue. but it could also be something else. like maybe theres sediment at the bottom of the tank and when u get gas it pushes the sediment around and is getting sucked into your pump screen when u start the car at the gas station.
could also be your fuel filter. your fuel filter could be clogged and need a new one. also could be due to sediment in the tank.
* B A N N E D *
itr motors dont have a maf
Re: My car acts up @ the gas station? (n1_egsex)
I had the same problem. 5.99 gas cap from Autozone fixed it. My other gascap wasnt keeping pressure correctly
just a quick suggestion check your gas cap for holes, or chips it might be the problem, if you have a buddy with the same car use his gas cap when you fill up and see if its the problem,
Re: (boostedEBP)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedEBP »</TD></TR><TR><TD CLASS="quote">same thing happen to my car. I just put the key to "ON" for about 8 seconds, then pumped the gas twice. It always started for me when I did it that way</TD></TR></TABLE>
pumping the gas does nothing on an efi vehicle when it is not running. also fuel pumps do tend to burn out right when you fill the tank so if the fuel filter or cap are not the problem dont be suprised if your pump dies on you completly.
Re: (galaxy2000)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by galaxy2000 »</TD></TR><TR><TD CLASS="quote">juss go to advanc auto partz an they will be able to help u.</TD></TR></TABLE>
LMAO. Help him with what? Selling him the wrong part?
Re: (electron_si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmmanek »</TD></TR><TR><TD CLASS="quote">I purchased a new fuel filter and same thing, i'll change caps to see if that a work thanks.</TD></TR></TABLE>
yea, i put a walboro fuel pump and still gave me the same problem.
I finally fixed it!!!! I upgraded to a walbro 255 and up the pressure to where it needed to be 47-54 without vacumn and it started right up @ the pump!!!!! Damn it feels good...
andylawcc
10-14-2006 05:03 AM
LvN
19
06-08-2006 06:58 AM
