my 95 civic coupe wasting alot of gas?? help!
Re: my 95 civic coupe wasting alot of gas?? help!
get under the car...
is it leaking?
if you dont want to crawl under there....get a cardboard box, put it under it there, and wait 6 hours, then pull it out.
is it leaking?
Your post is useless, every four days tells us nothing.
Fill it up and log the mileage and gallons on the pump and post it.
you need info, stick or auto?
do you smell gas coming from anywhere? be more specific check if the gas line has a leak, check the fuel filter fuel etc, it might be time for a tune up
For example, if you drive 347 miles and put in 10 gallons, you are getting 34.7mpg.
Does your trip odometer work? If so, set it to 0 next time you fill up your tank. Drive until the tank is low again, then refill the tank. Make a note of how many gallons of gas you put in. Then simply divide miles driven by amount of gas purchased, and you will have an accurate measurement of your MPG.
