mutiple error codes (p0325, p0505, p0171, p0174, p0170)
Old 03-26-2014, 01:56 PM
Trafficlightguy's Avatar
Default mutiple error codes (p0325, p0505, p0171, p0174, p0170)
swapped out the engine with the same type original harness
check engine on came new knock sensor oil pressure sender installed,
autozone pulled p0325,p0505, p0171,p0174,p0170
did the battery off reset and the 7.5 fuse reset at idle its fine but soon after driving it pops on
any ideas
Old 03-26-2014, 02:12 PM
Fish Twig
tony_2018's Avatar
Default Re: mutiple error codes
Whats your setup?
Old 03-26-2014, 02:18 PM
Originally Posted by tony_2018
Whats your setup?
it is all stock and manual transmission aftermarket short cold air intake
Old 03-26-2014, 02:42 PM
I never narc'd on nobody!
NotARaCist's Avatar
Rules, Thread Titles, Car Information, Searching, Trial Users, and Picture Posting
Read that, try again. The rules are rules, not general guidelines - they aren't optional.
Old 03-26-2014, 03:39 PM
If you loved me, you'd all sell me your magic cards to me today
doctorake's Avatar
Can you be any more vague about the car?
Old 03-26-2014, 04:04 PM
Former User's Avatar
This^
Post car information. It's required for ALL tech threads.
After the ECU reset, did all the codes return?
Old 03-26-2014, 05:26 PM
It's a 1996 civicEX d16y8 manual trans swap was the same block with the using the original
Intake, with all the original injector, it has a new timing belt water and oil pump and knock sensor
Old 03-26-2014, 05:33 PM
P0174 is not a 96-00 Honda Civic code.
P0171 indicates the engine is running lean or there's an exhaust leak.
P0325 begs the question of whether the engine has a knock sensor and whether its wire is connected to the ECU.
P0505 indicates you have an idle problem. Describe it.
Old 03-26-2014, 06:05 PM
Default Re: mutiple error codes (p0325, p0505, p0171, p0174, p0170)
Yes it has a knock sensor and yes it wired to the efi
The idle stay around 1500 rpm and sometimes drops to 1000 this is when the cars at operating temp
I cleared the ecu again and I went to a different vatozone and the only code was p0325
Now how accurate are these readers, like the cheap ones the sell and use w
shabz34526
Honda Civic (2006 - 2015)
09-13-2008 05:08 AM
pinky5
09-01-2008 02:29 PM
snouka
03-25-2005 12:16 PM
Solracer
02-18-2003 07:59 AM
shortyz
09-07-2002 09:15 AM
Quick Reply: mutiple error codes (p0325, p0505, p0171, p0174, p0170)
