Timing Belt moving side to side on cam gear
Old 09-27-2007, 04:40 AM
n77nxc's Avatar
Default Timing Belt moving side to side on cam gear
Guys,
Quick question...I am purchasing a hatch that has a GSR bottom end with a B16 head. I was looking at the timing belt last night and noticed the timing belt moves slightly side to side on the cam gears. What is causing this? Any input will be greatly appreciated.
Thanks!
Old 09-27-2007, 04:48 AM
nix94delsol's Avatar
Default Re: Timing Belt moving side to side on cam gear (n77nxc)
are they adjustable cam gears?
Old 09-27-2007, 04:49 AM
n77nxc's Avatar
Default Re: Timing Belt moving side to side on cam gear (nix94delsol)
Yes, they are AEM adjustable cam gears.
Old 09-27-2007, 04:51 AM
then thats your problem, screw with them there probly set funny
Old 09-27-2007, 04:52 AM
n77nxc's Avatar
Ok, sounds like its nothing serious. I will check them out. Thanks for your help bro!
Old 09-27-2007, 04:55 AM
haha what else am i gunna do during school other than come to hondatech?
no prob!
Old 09-27-2007, 04:57 AM
n77nxc's Avatar
Since I got your attention...the car has the following setup:
B18C1 bottom end
TypeR pistons and rods
TypeR crank, oil pump and water pump
New bearings and gaskets
Arp rod and head bolts
B16a2 head
Skunk2 stage 1 cams
TypeR valves
aem cam gears
375 rc injectors
aem fuel rail, fuel pressure regulator
fuel pressure guage
skunk2 intake manifold
70mm throttlebody
aem intake
ngk spark plug wires
Custom Johhny Tran header
2.5 Thermal exhuast piping
b16 tranny
exedy street clutch and lighten flywheel
255 walbro fuel pump
Any chance I can get away with some boost on this engine. Compression is high so that is why I'm asking.
Old 09-27-2007, 04:59 AM
i wouldnt go past 5 lbs
Old 09-27-2007, 05:01 AM
n77nxc's Avatar
Yeah, I'll prolly just leave it alone. The current setup runs strong. It dyno'ed 196whp and 132 ft/lb's.
Old 09-27-2007, 05:02 AM
sounds reasonable, i want a gsr for my car really bad
just low on $$$
Old 09-27-2007, 09:15 PM
been there done that
doood's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nix94delsol &raquo;</TD></TR><TR><TD CLASS="quote">i wouldnt go past 5 lbs</TD></TR></TABLE>
because we all know it'll blow at 6psi
Old 09-27-2007, 09:31 PM
H-T Poker champion
Hatchy-Ownzjo0's Avatar
Default Re: Timing Belt moving side to side on cam gear (doood)
I'd say you can go at least 10 lbs safely.. It's basically a brand new engine from the look of things. My friend was running his GSR at 14 tuned with stock internals with no problems... That is until he totaled it yesterday [crash, nothing to do with engine].
abusedvtec
02-12-2010 03:52 AM
cooteg6
05-19-2006 06:21 PM
cooteg6
05-09-2006 03:12 PM
AllMotorDA9
12
05-04-2005 04:19 AM
chet
05-15-2004 01:14 PM
Quick Reply: Timing Belt moving side to side on cam gear
