mini me in progress
mini me in progress
i am currently doing a mini me swap in my 95 civic. i have a d16y8 head off of a 97 civic ex and a d15b7 block from a 93 dx. i just wanted to know what distributor i should use because the y8 plug ins are different and the b7 bolt holes do not line up. also i wanted to know if i should use a y8 timing belt or a z6 timing belt. any help would be much appreciated.
Re: mini me in progress (jdmegcivic95)
https://honda-tech.com/zerothread?id=554053
There is a wonderful FAQ topic stickied at the top of this forum. I suggest you check it out... it can be very helpful.
when i got the y8 head i also got the manifold with it and i was wondering if it flowed any better than the z6 manifold. also i noticed there is no place for an intake air temp sensor. is that because they are different obd and an obd2 doesnt need one? and can i still use the y8 manifold without throwing a cel?
Re: (jdmegcivic95)
According to the myth, the Y8 intake manifold is the best OEM d-series manifold. On my Y8, the IAT sensor was on the stock intake arm. When I boosted it, I drilled it into the intake manifold. If you're going to install it properly, now is the time - when it's not installed.
Re: (_Cyclone_)
the y8 flows much better i know because i have this on my jdm d15b as for the iat the sensor is on the manifold on obd1 cars and on the intake for obd2 cars i just extended the wires for the plug and as for the actuall sensor i took it out of my old manifold and drilled a hole into my intake piping and siliconed it into place works great also when u do the swap be sure to plug the cruise control lines or u will get a vacumm leak and bad idle
Re: (northkai3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by northkai3 »</TD></TR><TR><TD CLASS="quote">the y8 flows much better i know because i have this on my jdm d15b as for the iat the sensor is on the manifold on obd1 cars and on the intake for obd2 cars i just extended the wires for the plug and as for the actuall sensor i took it out of my old manifold and drilled a hole into my intake piping and siliconed it into place works great also when u do the swap be sure to plug the cruise control lines or u will get a vacumm leak and bad idle</TD></TR></TABLE>
Ha, so I'm not the only one who forgot to plug this line in. After I changed my headgasket, I drove around for an hour before I realized what I forgot.
Re: (_Cyclone_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Cyclone_ »</TD></TR><TR><TD CLASS="quote">
Ha, so I'm not the only one who forgot to plug this line in. After I changed my headgasket, I drove around for an hour before I realized what I forgot. </TD></TR></TABLE>
yup it took some good old ht knowledge to figure that one out after my y8 im swap
Re: (jdmegcivic95)
nope because i didnt want to drill into that beautifull manifold so i extended the wires drilled a hole in my ebay intake and then siliconed the sensor/plug into place and then voila
Nisif
03-20-2009 05:43 PM
civicshowracing65
09-16-2006 12:13 PM
