milky oil in the head what can cause this
Old 04-28-2011, 06:35 AM
JdmJah's Avatar
Default milky oil in the head what can cause this
Need help my oil is like a chocolate milky color in the head when i took off the oil cap off the valve cover . can it be the head gasket. car dosent smoke also wanted what else can cause this ? thanks
Old 04-28-2011, 06:42 AM
The Grumpiest
grumblemarc's Avatar
Default Re: milky oil in the head what can cause this
Headgasket.
1991civiclx13's Avatar
is it overheating, coolant getting low, milky oil in the pan?
Old 04-28-2011, 07:09 AM
JdmJah's Avatar
it had a over heating problem but got a new thermostat didnt check the oil pan yet . can it be anything besides the head gasket ?
Old 04-28-2011, 07:12 AM
The Grumpiest
Warped head from constant overheating. Which would cause the gasket to fail.
Old 04-28-2011, 08:52 AM
NotAJDMFanBoy's Avatar
Do you do a lot of stop and go driving? Do you lose coolant?
It's common for condensation to mix with the oil, leaving milky oil. Normally when you get the motor hot it will boil off the water. Change the oil, avoid short trips if you can and keep an eye on it.
Old 04-28-2011, 09:06 AM
Jdm_driver4's Avatar
headgasket son. OR you need to grab some cookies for that milk and chocolate!
Old 04-28-2011, 10:44 AM
JdmJah's Avatar
its not over heating from what i can see and i know for sure head gasket lil bit of white smoke comes out the exhaust . thanks
Old 04-28-2011, 10:51 AM
Technical Hero
HondaPartsHero's Avatar
http://www.autozone.com/autozone/acc...ester/_/N-25dh
go loan this from autozone, don't guess, test
Old 04-28-2011, 10:56 AM
GoSickemRobert's Avatar
is it just in the cap or inside of the head itself? if its just milky residue in the oil cap its just condensation..
Old 02-19-2013, 02:41 PM
Fliptard's Avatar
sorry to bring up an older post. I just pulled my VC off my GSR and the whole looks like it's covered in white grease. It's all milky and ickk. It's my DD, no overheating, no loss in coolant and compression is good. The weather here is warm one day nad freezing the next. Is it just from that or what? I Also just switched to full synthetic oil, and it's not like that on the dipstick.
Old 02-19-2013, 02:54 PM
pityocamptes's Avatar
It is 100% normal if its on the cap head area, if its on the dip stick your screwed. Normally due to short drives in cold weather. Condensation does not have time to burn off due to the short drive/run...
Old 02-19-2013, 03:44 PM
apexi_rsx's Avatar
has the car set a long time? sometimes they build up moisture int he crank case from sitting.
Old 02-19-2013, 04:23 PM
Fliptard's Avatar
it's been sitting for 2 days. It's only white on the inside of the valve cover and on top of the cam rails.
Old 02-19-2013, 05:01 PM
v8killaz's Avatar
who cares if you say it doesn't burn oil or lose water or overheat.
is their a problem other than nasty oil on the valvecover? from what you said no so thats the only problem which is not a big deal. either take ur motor apart and clean all the sludge or drive the **** out of it
Old 02-19-2013, 05:03 PM
v8killaz's Avatar
**** it
Old 02-19-2013, 06:42 PM
Fliptard's Avatar
or I am just trying to make sure it won't cause issues later on, STFU and go back to your ghetto.
ericstambaugh07
06-25-2007 09:08 AM
boosted_TSi
02-01-2005 07:08 AM
G3gsr
05-20-2003 06:17 PM
PatrickGSR94
03-05-2003 10:02 PM
Quick Reply: milky oil in the head what can cause this
