Making OBD2 Alternator work into OBD1 engine.
Old 01-02-2010, 09:30 PM
hmtcrxsir's Avatar
Default Making OBD2 Alternator work into OBD1 engine.
Is there any way to convert the OBD2 integra alternator plug to work with the OBD 1 integra plug without cutting or splicing it? Can I open the alternator and modify the plug to use the OBD1 circular plug instead of the OBD2 rectangular harness plug? What number on the diagram do i change? I remember reading a post here on this forum regarding converting an OBD2 alternator to an OBD1 alternator
Old 01-03-2010, 03:47 AM
Seagull Management
94EG8's Avatar
Default Re: Making OBD2 Alternator work into OBD1 engine.
If both are Nippon Denso alternators you can swap the regulators. If both are Mitsubishi alternators you can probably swap the regulators. If they're different brands you're SOL.
Old 01-03-2010, 05:53 AM
Anon51's Avatar
you could just get the pigtail of the OBD2 alternator and splice it into the OBD1 Alternator plug. all the colors are the same except 1 I believe. and you just attach that to the last wire that isn't connected.
turboteg90
04-09-2019 08:13 AM
hmtcrxsir
08-02-2011 01:33 AM
Circaskaterr
Engine Management and Tuning
03-12-2010 04:42 AM
se93
09-17-2005 08:27 PM
ID_ten_T
12-18-2003 11:01 AM
Quick Reply: Making OBD2 Alternator work into OBD1 engine.
