major tire blow out story (ELCTRICAL ISSUE OMG)
SO THE PASSENGER TIRE BLEW OUT ON THE FREEWAY CAUSING IT TO RIP OFF BUMPER AND TURN SIGNAL /CORNER LIGHT. LEAVING THE WIRES EXPOSED! IT ARKED OFF AND THEN I SMELL BURNT PLASTIC AND SEE ALOT OF SMOKE COMEING FROM THE UNDERDASH FUSE PANEL! THE TURN SIGNAL RELAY WAS SO SHOT! I REPLACED IT AND CHECKED THE TURN SIGNAL FUSE. SO THE HAZARDS WILL WORK BUT I HAVE NO TURN SIGNALS! I TRIED A COUPLE OF BYPASS TRICKS BUT IT WAS A FAIL! I RECONNECTED THE CORNER LIGHT GETTING IT TO WORK! OK SO REALLY WEIRED WHEN I TURN THE HAZARDS ON AND PLAY WITH THE TURN SIGNALS THE NEW RELAY FLASHES/CLICKS RAPIDY AND BY ACCIDENT IT GAVE ME BAK MY SIGNALS. UNTILL I HIT THE HAZARDS AGAIN IT MADE THAT RAPID FLASHING NOISE N LOST THE SIGNALS AGAIN! OH BROTHER, WHAT TO DO !
The Grumpiest
Re: major tire blow out story (ELCTRICAL ISSUE OMG)
1-Stop typing in all caps.
2-Stop trying to rig **** and actually replace the messed up wiring. You might even need to get a new harness. Inspect the fusebox thoroughly.
3-Obtain a real wiring diagram and get your hands on a multimeter.
4-Failing all of this, take it to someone that knows what they are doing.
Matt_2078
16
10-20-2005 09:01 PM
