Maintenance required light on a 2001 Civic...
Old 02-11-2003, 08:43 PM
TheSwift1's Avatar
Default Maintenance required light on a 2001 Civic...
quick question...hope i'm explaining this right..
my g/f has a 2001 Civic EX...it's got a little over 7,000 miles on it and she just got an oil change for it...but before she got an oil change, the "maintenance required" light would come on for a while, then go off...well, now it's permanently on...
i have a 99 Civic, and i pretty much know my car inside out, but i've never worked on a 2001...with my car, i know there's a indicator that will show red after so much miles to remind you that you need a routine checkup (oil change, etc...)...to reset it is simply a matter of sticking ur key in the little slot on the instrument cluster cover...
now, with her car, i was thinking that maybe this was an indicator like this? i didn't really spend much time on the subject, as the car drives just fine, and i figured that this was the case, so before i tried resetting her ECU by disconnecting the battery, i thought i'd ask the question to u guys just to save some time...
Cliff notes: g/f's 2001 Civic's "maintenance required" light is on...bone stock...a little over 7,000 miles...how and should i reset it?
Old 02-11-2003, 08:44 PM
B2FiNiTY's Avatar
Default Re: Maintenance required light on a 2001 Civic... (TheSwift1)
It is just like yours. Check her owners manual on how to reset it.
It's just a light to remind you to get maintanence done.
Old 02-11-2003, 08:47 PM
aw1234dude's Avatar
Default Re: Maintenance required light on a 2001 Civic... (B2FiNiTY)
put a small sticker over it.....yeah i thought there would be like a key hole like my si gauge cluster has...maybe they put the reset keyhole somewhere else.
Old 02-11-2003, 08:48 PM
TheSwift1's Avatar
thanx for the quick reply...maybe i should have done a search before becuase i just found a post on it....DOOHHH!!!!
Old 02-11-2003, 08:50 PM
TheSwift1's Avatar
according to another post....ur supposed to:
take key out of ignition..
push in odometer button and hold it...
put in key in ignition and turn to ON..
hold in button...
hopefully it'll work...i'll have to try tomorrow..
Old 02-11-2003, 08:53 PM
LL95's Avatar
To reset the maintenance lights on 2001 Civics is as follows:
with the key in the ignition, hold down the **** on the right(it is the one for the brightness of the cluster). Then turn the key to the ON position or just start the car, WHILE holding the button. Keep holding till the lights goes off(like 10 to 12 seconds). I am sorry if I can not remember exactly which ****, the one on the right or left(it is pathetic I know). Try the right first. The maintenance light on those Civics will come every 7,500 miles.
Lee
Old 02-11-2003, 09:10 PM
TheSwift1's Avatar
Default Re: Maintenance required light on a 2001 Civic... (LL95)
cool...thanx!
Old 02-11-2003, 09:12 PM
LL95's Avatar
Get back to me if that doesn't work.
Lee
Old 09-01-2023, 12:47 PM
SnarlaHazard's Avatar
That worked! Thanks!
kloscivicsi
Honda S2000
03-30-2007 05:05 PM
Peruviann83
02-20-2007 08:59 AM
jdm_eg
01-04-2005 12:56 PM
blackriceman
03-29-2004 08:33 PM
:jdmshmaydm:
06-19-2003 06:44 AM
Quick Reply: Maintenance required light on a 2001 Civic...
