Main Relay is working but not recieving ground from ECU
Old 04-05-2007, 06:12 PM
lledcomp's Avatar
Default Main Relay is working but not recieving ground from ECU
The main relay in my 99 honda civic is working but the fuel pump isn't priming itself so I found out that if I ground out the fuel pump relays ground wire on the main relay the fuel pump starts right up and primes itself fine. I tracked that ground wire from the main relay straight from it right down to the ECU. Does this suggest that my ECU is fried? I'm trying to find an ECU that I can swap with the AEM that I have in the car to see if it will power the fuel pump right. Was just wondering if I was on the right track?
Old 04-05-2007, 06:20 PM
93FlatBlackHatch's Avatar
Default Re: Main Relay is working but not recieving ground from ECU (lledcomp)
Yeah, your on the right track. To me it sounds like your ecu is bad. I had the same problem and that was the cause.
DDTECH
05-11-2012 08:42 PM
krysted9354
20
04-08-2009 03:32 PM
red_honda_racer
11-22-2007 12:33 PM
JDMB20TDA
08-18-2007 08:45 AM
2 0 3
07-30-2006 05:36 PM
Quick Reply: Main Relay is working but not recieving ground from ECU
