Main Relay Location-EK
Re: Main Relay Location-EK (EKHWhat)
its on the right side .. on side the dash board there is a screw.. remove it and pull off panel... then you will be able to see the screw holding them main relay
Re: Main Relay Location-EK (gezzuzz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ThatGuy4life »</TD></TR><TR><TD CLASS="quote">For future references:
To get to main relay on 2000 civic si, you need to reomve the panel on the far right side of the dash
then drop you glove box look inside where the glove box was to the right and you will see the main relay (don't mind all the wires you see in my pics, those are to the relays for my door poppers so yours won't look exactly like mine)
you can also see it from outside
It's being held by a 10mm bolt
remove the bolt remove the relay from the bracket and remove the connector, install in reverse.</TD></TR></TABLE>
sidewayz32
14
11-12-2005 06:40 AM
ian.
09-30-2004 03:47 PM
