Main Relay location
Old 09-16-2008, 06:14 AM
jordanprince's Avatar
Default Main Relay location
where is the main relay located in a EK hatchback?
Old 09-16-2008, 06:19 AM
crick_james's Avatar
Default Re: Main Relay location (jordanprince)
i would assume its in the same spot as my ek coupes, which is on the passenger side of the glovebox, take off the side panel on the passenger side of the dash, remove the glovebox and take out the two bolts and there ya go.
Old 09-16-2008, 06:22 AM
thanks ill go check
Old 09-16-2008, 06:26 AM
Default Re: (jordanprince)
not a problem.
Old 09-16-2008, 06:31 AM
found it...its not under the plastic tho I had to drop down the glove box and it was sitting in this space close to the door
Old 09-16-2008, 09:15 AM
yeah, from factory it should be located on the the farthest side of the dash, by the glove box.
black94lude
06-01-2010 09:22 PM
tpot90
03-07-2008 12:50 PM
EKHWhat
03-17-2007 11:41 AM
sidewayz32
14
11-12-2005 06:40 AM
ratbelly
07-29-2005 07:12 PM
Quick Reply: Main Relay location
